Vacuum lines
OK, so im chasing down issues little by little. Little peice of advice: If your gonna tear your car apart, take ALOT of pictures and notes to where things go.
If you have been following my threads I got the rocker arm issue solved, the oil plug problem solved, now onto my next issue.
Vacuum lines.
Does someone have a picture of where they all go, I have about half hooked up but am missing a few connections and some of them have broken so i cant use the " this one is long enough to go here" guide.
There are two nipples on the left side of the intake and one on the right??? Cant figure out what goes there.
So if someone could go out to their garage and take 3 or 4 pics of their engine and more specifically the vacuum lines that would be great!
Thanks
John
PS. also have about 4 plugs from the wiring harness that I don't know where they go either, so this will help two fold.
Thanks again,
John
Vacuum lines.
Thanks
John
Thanks again,
John
HVAC and FPR on the passenger side, OPTI, EGR and PCV on driver side.
shbox's website has pictures for all of that including a spread out wiring harness with all connectors clearly labeled. most of it is easily found with google images if you dont feel like browsing the site.
google images
engine harness
search term used: "shbox engine harness"
http://shbox.com/1/1995_Z28_engine_harness_A4.jpg
vacuum lines
search term used: "shbox vacuum lines"
http://there_are_a_lot_more_than_i_care_to_link_to.com
engine harness
vacuum lines
There are all kinds of pictures in the Component Location Views section of my website and there is also an emissions sticker under your hood on the radiator cover that shows where all the lines go.
