Shift light/dash mounted tach questions
Old Feb 13, 2012 | 10:21 AM
ahritchie's Avatar
Question Shift light/dash mounted tach questions
I've decided I need either a shift light or a tach with shift light for my new 383 combo with 6spd.....it's got so much power it seems pretty easy to over-rev it accidentally if the tires break loose suddenly (which happens a lot ). My stock shortblock led a short life due to being over-revved so I don't want to make the same mistake twice. How bad is visibility affected with one of those big 5" tachs mounted on the dash above the middle AC vents? The car will see mainly DD duty so reduced visibility is a concern; maybe just a shift light would be better?
Here's the two options I have been looking at:
http://www.jegs.com/p/JEGS-Performan...15170/10002/-1
http://www.jegs.com/p/Auto-Meter/Aut...52169/10002/-1
Somebody with a big tach or shift light give me some advice on this please; I'm open to suggestions.
Old Feb 13, 2012 | 04:15 PM
97pontta's Avatar
I used one of these from the WS6store
http://www.ws6project.com/user_stor/...shift-light-1/
Its a sleek little unit. I was able to run the wire up the interior panel and used double sided 3M tape to stick it to the dash. I didn't think the tape would hole long but its been over 2 years and it hasn't fallen off yet.
Old Feb 13, 2012 | 04:22 PM
guppymech's Avatar
I researched shift lights recently. Alot of people use the Harlan shift light and like it. Most mount it in the round vent opening at the base of the 'A' pillar trim for defogging the side window.
Old Feb 13, 2012 | 04:34 PM
1badzee's Avatar
I have the shift light comparable to the bottom link you posted (mine is made by Proform though). I removed my window defroster switch and placed the shift light in there. Completely out of sight, but when racing at the track at night you can clearly see the light. Those things are ridiculously bright! I am planning on removing it/selling it and getting a smaller LED one. I have a rather large tach (simply because mine is waaay off for some reason) but I did not like the look of mounting it on the dash. It looks out of place IMO. I have it mounted in the CD holder thing on front of the shifter. I only use it for reference when datalogging/tuning. I do not really look at it at the track. I shift based on sound and the bright shift light blinding me indicates it is time to shift
Old Feb 13, 2012 | 05:09 PM
RocitSS's Avatar
I mounted mine through the pillar on drivers side. No visibility issues, and damn sure lets you know when to shift. I post a picture in a little bit.
Old Feb 13, 2012 | 05:20 PM
RocitSS's Avatar
Old Feb 13, 2012 | 05:35 PM
BrianSF-GA's Avatar
I will be installing a shift light very soon ... same boat as you, an M6. Personally, I don't care for "monster" tachs unless it is an all-out drag car. My plan is similar to your second link, the Auto Meter Pro Shift-Lite, mounted to the column. I have seen several of the pillar vent mounted shift lights and I like them as well.
I was sent this photo by another member. Hopefully, he won't mind me posting it, but it gives you an idea.
Old Feb 13, 2012 | 05:47 PM
BrianSF-GA's Avatar
I believe the Auto Meter 5334 requires the use of an Autometer tach or interface to allow you to program the desired RPM (someone chime in here) so you need more than just the "5334" shift light. The Auto Meter 5340 is a stand alone light that uses "pills" to turn on the light at a given RPM in a similar fashion as the dip switches in the Harland (and similar) shift lights.
Old Feb 13, 2012 | 05:54 PM
RocitSS's Avatar
Yeah, mine is my bracket car as well so the big tach is a lot easier to keep a consistent launch RPM from. Sorry for the massive pics btw.
Old Feb 13, 2012 | 06:43 PM
guppymech's Avatar
Hey Brian that Autometer 5340 looks like a nice setup on the column. I'm going to look into getting one.
Old Feb 13, 2012 | 06:56 PM
BrianSF-GA's Avatar
"guppymech", post up some photos when you get it mounted. I will do the same when I get mine in ... I still have a two-step, line lock and rear slicks to get and install. My front runners should be in anytime. My time is quickly running out .... the tracks here will be open for test & tune soon. I cannot wait.
Old Feb 13, 2012 | 07:47 PM
Sc0tt30's Avatar
I can't really tell from the pictures but what did you use to mount it to the pillar? I can't tell if you have a screw holding the bracket to the pillar or not. That is the same place i want to mount mine.
Old Feb 13, 2012 | 08:18 PM
brokenbird's Avatar
I had mine on the pillar and I bolted it to the car and used a nut on the bolt to hold it all together
Old Feb 13, 2012 | 08:28 PM
Sc0tt30's Avatar
I figured that would be the best option. Thanks
Old Feb 13, 2012 | 09:07 PM
RocitSS's Avatar
I used two larger stainless sheet metal screws in the mount. Holds perfect and keeps it right where I want it.
Old Feb 14, 2012 | 01:21 AM
meine96ws6's Avatar
I have seen smaller led style shift lights..they looked great and didn't obstruck your view
Old Feb 14, 2012 | 08:02 AM
ahritchie's Avatar
A lot of good ideas here...I like the idea of the steering column mounted light; I also have an extra spot in my gauge pod to try to stick one.
I'm leaning toward the low profile look of just the shift light to not attract too much attention
Old Feb 14, 2012 | 10:36 AM
RocitSS's Avatar
I would agree with just the light then cause the monster is what almost everyone mentions first time they see it.
Old Feb 14, 2012 | 10:43 AM
IronOutlaw's Avatar
Check this out. Im gonna try to replicate this one day.
https://ls1tech.com/forums/appearanc...l#post14494553
Old Feb 14, 2012 | 11:47 AM
FormulaJoe's Avatar
^^I saw that too, a bit ago.. I like the idea, and it is very clean, but does it light up when you reach your preferred RPM?
