Build me a 383...
You are posed with two choices: Gamble with the 200k short block and add a heads/cam package, or rebuild the bottom end and do a cam swap.
Pros of option 1 - 400+whp easy using GOOD parts.
Cons of option 1 - Likely a seriously short lifespan of the stock shortblock. Could last another 20k, could last 500 miles...there's just no way to tell.
Pros of option 2 - Far more reliable than option 1, allows for future enhancements without risk of needing a rebuild.
Cons of option 2 - 350-360whp, since you won't have any money left over for any headwork, just a basic cam swap, supplemental parts, and tuning.
For bearings and rings, let your engine builder decide on what's best. That way you put the ball in HIS court if anything were to ever happen to the motor. That way your hands are washed from the situation.
Having said that, I would request good Clevite bearings and Total Seal rings. They've treated me well so far and countless other guys on the forum.
Your assumed price of $1000 to rebuild the bottom end will still not get you very far, even using the above economical option. The machine work (boring, line honing, hot-tanking, magnafluxing, assembly, etc.) will cost more than the sum of the parts. Plan on at least $1500 for the bottom end. That leaves you with ~$1500 for a cam swap plus tangibles - enough to do it (most of the way) properly. There's a few threads explaining exactly what I just described and the associated costs. A few keywords in the search bar should get you the info you need.
just my .02
i really tried to do a good job, multy layer head gaskets. ls7 lifters, comp cam chromoly pushrods, and take good care of all the little parts, and though its just a little 346 that thing ended up costing alot of money,
honestly i see big *** motors here on the classfields for simular prices all the time..
the plan was to use it in my car this summer, but i do admitt i think about goin 383 with it all day long.
i dream about bulding a 400cid+ aliminium motor. but honestly that is not goin to happen any time soon.. and for me to build a solid 383 shortblock and get a patric G spec'd cam and use my top end would really cost about half the price it would cost me to get the 4xx motor.
