View Poll Results: What to spend my money on?
complete UMI front suspension and bank rest
4.55%
Weld RT’S with tires
4.55%
Moser 12 bolt rear with 4.10s
86.36%
other
4.55%
Voters: 22. You may not vote on this poll
Help spend my $$
Old Mar 11, 2012 | 07:27 PM
1961ba427's Avatar
Originally Posted by Catmaigne
There should be an option for budget 8.8 build to make your dollar go further.
Originally Posted by 95sscamaro
Well I got a Moser 12 bolt for $1500 shipped, has a posi and 30 spline axles, Moser diff cover, and the best part it only has 500 miles on it. However there is one down side it has 3.73s in it, I’m thinking that I will try it out and if it comes down to it I’ll put some 4.10s in there.
Sounds like you got a great deal. I prefer 4.10's over 3.73's with a t56, but they are close enough that I wouldn't disturb a properly set-up rearend for the difference in ratio...even if I already had the parts.
I doubt you could have built an 8.8 to save much $$ vs. the deal you found.
Old Mar 11, 2012 | 09:19 PM
95sscamaro's Avatar
^ yea it was too good to pass on it, even if it doesnt have 4.10's. I looked into a 8.8 but it wasnt any cheaper with all the fab work plus parts, also this is my DD so i cant have a ton of down time.
Old Mar 12, 2012 | 06:04 AM
bufmatmuslepants's Avatar
As stated above, if the 3.73s are set up properly I'd just leave them alone for now. That's a killer deal for $1500. Does it have a trutrack in it or Detroit locker or spool?
Old Mar 12, 2012 | 07:12 AM
95sscamaro's Avatar
It has a trutrack, also it comes with ls1 brakes!
Old Apr 3, 2012 | 03:13 PM
lt1needingboost's Avatar
i vote rear very ez gotta put the power down
