Opti number 5 in 3 months
#42
Village Troll ![](http://jameskellock.tripod.com/sitebuildercontent/sitebuilderpictures/rsman.jpg)
You mean parkerizing?
#45
Here it is the opti cap was sucked down into the rotor causing the rotor to get eaten up by the cap. Opti is still good replaced the rotor and not going to run vacuum hoses anymore.
This could also be the reason for high rpm otpi failure maybe the opti can handle high rpm but people have overlooked the vacuum?
#48
Yea thats a good question..I have check valves on them and running to the stock location, unless Im pulling too much vacuum at the top end because of the big cam then I don't see what else could cause this malfunction
#49
Have you checked to see if the fresh air hose is blocked? This would cause vacuum to build up inside the opti. The highest vacuum you will see is on deceleration from high RPM.
#52
WOW
so then the elbow hose does not pull on the OPTI? I thought it did as well.
I dont know which one hose goes where...mine is setup in stock locations.
But my thought was that the one going to the intake elbow would also for sure create a vacuum.
So then GM designed for it to pull or vacuum fresh air from the elbow? the whole time pulling the ionized air from the Cap and rotor division through past and into the Optical sensor area and then throw that into the manifold?
That setup blows chunks....i dont want runoff from the cap and rotor area in the opti area. Why mix the two?
Also wouldnt it be hard to pull air out of the elbow especially under load if the throttle body is doing it's thing...and pulling mazda' and rustangs into it's blades...possibly also could lodge one and block that passage all together. If that was the intended design maybe that's what's happened here maybe too much vacuum on the intake side prevented flow.
I'm thinking id rather drill another fitting into opti side and keep both halves somehow not mixing their runoffs.
Are you sure the intake elbow hose is not vacuuming as well?
#53
from the looking at everything, it looks good unless this check valve in the fresh air line is no good. but seems to work fine. The vacuum has to be minimal at the fresh air line, unless it pulls suction from the intake
#54
The hose from the elbow is the fresh air intake to the Opti and provides no suction. The hose from the intake is the suction line from the Opti and should have the check valve on it. Both of these lines should be free of clogs.
To check the venting operation, hook a mityvac to the suction line and see if it draws. It should draw easily and if it holds a vacuum, there is a clogged hose. If you dont have a mityvac, just stick the suction hose in your mouth and start sucking.
Hopefully if draws air easily.
If the venting is working fine, there is no way that vacuum is collapsing the opti cap. I have seen in Optis past were the rotor button did slightly contact the lower white plastic housing and the cap so a little triming was needed on the rotor. Once its assembled, when you turn it by hand, you should hear no scuffing sounds which would indicate rotor rubbing.
Lets make sure the venting is working properly first.
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
#55
The line with the little "UFO" disc filter and check valve should go to the intake manifold, NOT to the intake elbow.
#56
The diagram is labeling both as intake.
http://shbox.com/ci/opti_vent.jpg
In other words they both suck air out. That would make more sense....what you guys are saying is that GM willingly passed ionized air into the Optical sensor side and THEENNN sucks it out.
I think that what's happened to black3rdGen is his hogwild cam produces sooo much vacuum and wants inhale the world....that it was more vacuum than intended.....also HE SEALED the dizzy cap with gasket mojo. That prolly didn't help the situation. As the unsealed caps would likely just pull air through its seams if a normal cam were to have enough vacuum to pull hard enough.
Does anyone have a diagram showing the GM intended air flows? supporting the fresh air theory? altho it has to pull it from somewhere i agree...or should.
I think it sucks air out and into the intake elbow and reburns the ionized mix from the cap and rotor side. The gasket sealant and his engine's CFM requirements made it collapse onto itself.
#57
I added a check valve to the fresh air line just in case of backfire it doesnt cause destruction to the opti, the check valve added on the fresh air side is not pulling easy feels like its getting stuck going to swap it out.
#58
Ok so the one from the intake elbow goes to the dizzy cap. The one from the intake mani goes to the opti housing body/tube? It's covered in loom so I cant tell which one goes where.
In other words they both suck air out. That would make more sense....what you guys are saying is that GM willingly passed ionized air into the Optical sensor side and then sucked it out.
I think that what's happened to black3rdGen is his hogwild cam produces sooo much vacuum and wants inhale the world....that it was more vacuum than intended.....also HE SEALED the dizzy cap with gasket mojo. That prolly didn't help the situation. As the unsealed caps would like just pull air through its seams if a normal cam were to have enough vacuum to pull hard enough.
Does anyone have a diagram showing the GM intended air flows? supporting the fresh air theory.
I think it sucks air out and into the intake elbow and reburns the ionized mix from the cap and rotor side. The gasket sealant and his CFM requirements made it collapse onto itself.
Consider a desktop PC case, if both fans are installed either blowing in or both sucking out, the intended functional airflow will not be present and a malfunction is the result.
OP, remove the check valve from the fresh air hose from the elbow. Considering the bad luck with you and Optis, there is no need to try to re-engineer the venting system until the root problem is determined. FWIW I cant see a backfire causing Opti damage considering the small size hose in fact I would be more concerned why your concerned with backfires.
If that particular check valve were installed backwards, that would mimic a clogged hose and then likely suck the cap inward causing the problem. This could be the root problem. Again, grab intake hose and start sucking on it and reply back with the result. It will either draw air or not.
#59
imo the two lines can not provide suction at the same time because you have to have an air supply in order to suck said air out. The intake provides the intended suction to the intake hose. The other acquires fresh air from the elbow to be flowed into the opti.
Consider a desktop pc case, if both fans are installed either blowing in or both sucking out, the intended functional airflow will not be present and a malfunction is the result.
Op, remove the check valve from the fresh air hose from the elbow. Considering the bad luck with you and optis, there is no need to try to re-engineer the venting system until the root problem is determined. Fwiw i cant see a backfire causing opti damage considering the small size hose in fact i would be more concerned why your concerned with backfires.
#60
The intake elbow receives vacuum as well from the engine....the other thing is if this would to not be a problem and air could still be drawn from the elbow even though the engine is pulling from there....their blending air particles from the rotor side up and thru the optical side.
someone should try to mityvac the intake mani hose while the engine is running at idle and other rpm ranges to see how much vac can be applied.
