Opti number 5 in 3 months
Shoebox one more question could a bad tach cause a electrical problem to the opti..I'm stepping back and trying to analyze every angle..I know that when I hooked up my tach I had a constant 12 volts to the tach sending wire and when car was running it would pulse also..usually a sending wire does not recieved a constant 12v and I noticed since I installed this autometer tach that I would see the needle jump out of no where even when opti is new..when I had previous tach I never had this problem..first opti spun a rotor which is common the. I put new tach in and one month later bad opti and it had continued breaking could this tach be my problem??
Ive had two 1994 fbodys, a Z28 and now a Trans am. Z28 had 140k on it, original opti, ran fantastic. The 94 trans am has 125k-ish on it, original opti, no issues, and ive had it apart to do a cam swap.
Blowing up 5 of them in 3 months is crazy.
What are you doing when they go? Idling? ***** out? cruising?
What have you done to the car? Why is the cam dowel to long? Did you install a cam? Are you sure its in correctly? Is the retainer in correctly? Are you dot to dot? Are you single or double timing chain?
Is this a 3rd gen swap (your username?). If so are you sure your using the correct opti?
Next time it blows, if it does, I think you should take off the timing chain and check it all out. Make sure everything is seated correctly. Make sure the bolts that hold the cam sprocket on are seating into the opti.
I would also stop taking GM optis apart. They are good units, Think of grandma in her buick roadmaster, or gangster in his impala SS with 170k miles on it, Or old man in his white 94 vette convertable with fugly red interior who lives in florida....I bet none of them have opened an opti to locktite bolts, and I bet none of them have gone through 5 of them in 3 months.
This is the cam retainer up front. Behind the cam sprocket. I would make sure its good next time it blows up, wouldnt this be the only thing that could allow "cam walk"?
