Nice solid gains. Kinda shows where I'm at myself. Except I don't have roller rockers, but I do have long tubes and a tune. I thought my close to stock numbers were low but I was at 236hp/276tq with a cutout. Keep up the documentation and track times.
The first time I dynoed a stock A4 LT1 people thought it was low at 230, but since then every other one has been right in that range. I've never owned a 6-speed LT1, but they seem to dyno a good amount higher stock. A friend's was in the 260 range with a cold air, cutout, and 4.10 gears (which probably hurt the numbers).
We'll keep the progress updated.
Originally Posted by BizZzatch350
Nice numbers, gears and converter should put that thing in the mid 12s easily
Sounds like a converter and cam have moved to the top of the list. He has the stock 2.73 rear still in his garage. If the cam doesn't work well with the 3.42's then we'll rebuild the stock rear with 3.73's.
Will the CC306 work with 1.6 rockers on the stock bottom end and stock heads?
Thanks!
