Surging & Hesitaion
. Im just having trouble figuring it out because im kinda stuck dealing with it on my own. im in college and dont have the money to have the dealer deal with it so details would be great. im kinda stuck being my own mechanic! anyone else want to help
now go check this as a possible source of your problems
http://shbox.com/1/4th_gen_tech2.html#HVAC_vacuum
your looking for a vacuum leak, its not easy, nor is it impossible. the mityvac has a gauge on it, you squeeze the handle and it creates a vacuum and has a gauge on it to show how much vacuum you are building. if the gauge doesnt build vacuum at all, or it drops quickly, you have found the leak. hit the auto parts store and buy some replacement hose.
Why are you so affected by my attitude? damn talk about sensitive but with all due respect thanks for the great info. could the cause of the hesitation or surging have to do with the ignition system or only vacuum? ill take that link and get some info. Thanks man.
hesitation and surging, yes can be caused by a vac leak. it might not be all of your problems, but lets address one thing at a time. you could also take all the vacuum ports and tape them off with electrical tape, yea it will throw codes, but if it settles your problems, you know its a leak. spark can have its issues, you can test your ICM and OPTI and Coil all with directions from the shbox website. you will need a decent mulitmeter that does voltage & resistance(ohms) but it will help you greatly to spend a few $$ on it 50-100 depending upon brand and such, but get a digital one, youll use it more than you think. plugs and wires arent a cure all, but if you cant remember the last time you changed them, it might be it too. also to fill out what mods you have done to the car, and anything you did recently helps too
