Throttle body relocation?
Old Feb 28, 2012 | 08:33 PM
zeeboost's Avatar
Default Throttle body relocation?
I've been building up an LT1 to use in a custom project I have, and in order for me to use it I would need to scoot the throttle body back roughly 2-3 inches. The only way I can see me using this engine is if I throw a carb manifold on there and run it like that, which defeats the purpose because other than the reverse flow cooling, it has nothing more to offer than the sbc I'm currently using. Do I have any other options as far as relocating the throttle body? (I was wondering if any aftermarket intake manifolds offer this, but it wouldn't make sense to me why they would)
Old Feb 28, 2012 | 09:30 PM
zraffz's Avatar
I can't speak about aftermarket intakes (your only option is to convert a gen 1 FI intake to fit the LT1), but generally speaking if you keep the throttle body in a strait line from the manifold it shouldn't have any issues... problem starts when bends get thrown into the equation.
Old Feb 29, 2012 | 07:59 AM
96capricemgr's Avatar
What about putting the TB at the rear?
Old Feb 29, 2012 | 09:19 AM
azlt's Avatar
Now that i wanna see!^^^
Old Feb 29, 2012 | 09:38 AM
Can the OP post a few pics of where this is going? Maybe we can come up with some other ideas.
The rear mounted TB was something I saw with a roots blower on an LT1 years ago, not exactly a stock intake but seems to me if you have the room it would be easier than putting the TB right in the number 1 intake port as it would moved 3" back. I saw someone else modify an LT1 intake for two top mounted stock TBs but he never got it to actually improve anything.
Old Feb 29, 2012 | 10:36 AM
1SWT95Z's Avatar
How about a sheet metal LT1 manifold? I've been tossing around the idea for a couple years now. If anything you might end up gaining a few hp going this route and be able to move your tb to where you want it.
Old Feb 29, 2012 | 12:33 PM
quik95lt1's Avatar
yea lets see some pics of whats goin on im sure we can come up with a plan for ya.....
Old Feb 29, 2012 | 08:28 PM
97Z28SS's Avatar
If you have a sbc fi intake like a Victor EFI then you could use a sheet metal elbo and turn it around backwards. I have this Nitrous Outlet 860 elbow for sale lmk if you're interested.
http://i1110.photobucket.com/albums/...T1parts012.jpg
http://i1110.photobucket.com/albums/...T1parts011.jpg
http://i1110.photobucket.com/albums/...T1parts010.jpg
Old Mar 1, 2012 | 01:09 AM
zeeboost's Avatar
It's basically just for a ram air setup that I'm trying to properly set up. It's literally within an inch from the opening of the hood scoop, and I need at least a few inches to run some ducting and a filter. I planned on using a MAP sensor so I wouldn't have to worry about the MAF taking up ducting space.
Throttle body in the rear wouldn't work for me, because the engine sits really close to the firewall, and the hood latch wouldn't allow for it (reverse hood). And I'd love to build a sheetmetal intake, but that's out of my league.
97z28ss - Your idea has a lot of potential, but do you just use any sbc fi intake? Like off a vortec or something?
Old Mar 1, 2012 | 07:50 AM
quik95lt1's Avatar
can run one like i am i run a Victor E EFI............works good but on a milder motor id run something smaller.....
Old Mar 1, 2012 | 08:42 AM
Why don't you tell him what it cost to setup an intake like that?
Old Mar 1, 2012 | 09:30 AM
quik95lt1's Avatar
yeaaaaa hes not gonna like that part lol
Old Mar 1, 2012 | 10:36 AM
zeeboost's Avatar
Oh geez, I'm scared to ask how much. That would be the setup I'm looking for, the only thing is I'd have to see how high that elbow sits. With the current sbc in there, in order to be able to close my hood I had to use a low profile air filter and trim the mounting stud to where it sits only an inch above the filter.
Old Mar 1, 2012 | 10:50 AM
I believe the "usual figure" thrown around is plan to spend at least $1200 on the swap by the time you are done with new rails, braided line, machining etc.
Old Mar 1, 2012 | 11:01 AM
quik95lt1's Avatar
yea i mean you could go less agressive than i did ive got way over that in mine with me doing all the machining/porting more mild setup figure
350 intake
150 elbow
350 tb
100 rails
400 injectors
200 plumbing
then machining.....
Old Mar 1, 2012 | 11:06 AM
WS Sick's Avatar
Of course if you were handy you could fab up the elbo yourself and use the LT1 style TB. Also there is a few cheaper manifold starting points, they may not flow as good as the one used in the example above , but non the less they have the FI bungs already there.
Old Mar 1, 2012 | 11:34 AM
Puck's Avatar
The 860 elbow is one of the lowest ones you can get for an lt1 without causing too much of a restriction.
I have a better flowing intakeelbows piece for sale as well, but if you are worried about space the 860 is a better choice. I had one of those before selling it and it is a quality piece.
Old Mar 1, 2012 | 12:07 PM
AChotrod's Avatar
I also have a Vic EFI JR already set up for a LT1 and a 860 elbow. The elbow is a real nice piece and the intake is fully ported by LE with a N.O. custom spray bar. Still debating if Im going to use it.
Old Mar 1, 2012 | 12:20 PM
zeeboost's Avatar
quik95 - So why are you not able to run the factory fuel rail with a different EFI manifold?
Also, could you elaborate a little more on:
Originally Posted by quik95lt1
then machining.....
Old Mar 1, 2012 | 02:33 PM
quik95lt1's Avatar
some manifolds you may be able to make it work but IMO it would look very hack lol.....on an intake like mine it would require even more fabrication to mount them as well asl plumbing.......its just not worth it
as for machining youve got a couple options......easiest way to bolt one of these up is to machine holes at the new angle to use the outer 8 bolts with machined spacers to make the angle correct......then the middle four becuse of their location on mine i tapped my head for the sbc bolt holes.....the outers if i put them to the lt1 pattern i couldn't get them in because the position of the runner........hers a pic you can see the spacers i made to correct the angle......
