Dual 2 1/2 inch or 3?!?!
Old Mar 13, 2012 | 08:25 AM
jaycenk's Avatar
2 1/2's even over the axle can be done with stock parts still in stock places. Pan hard allows a slight left right movement of the rear as it travels up and down. Changing the geometry changes the characteristics of the way it moves.
Old Mar 14, 2012 | 05:48 PM
BLK93TA's Avatar
Thanks i don't want that! If i can run the pipes without having to do that then thats even better for me! 205 dollars cheaper too lol
Old Mar 14, 2012 | 07:10 PM
F0x Slaughter's Avatar
I run dual 3" dumped before the axle.
Bought the piping and had it fitted and welded for under 80 bucks.
Old Mar 14, 2012 | 09:21 PM
JUSTINSWS6's Avatar
Originally Posted by LT1
I would recommend 2.5" setup.
I'm running 3" x-pipe to dual 3" muffler and 3" inch tail pipes, it sounds awesome and makes good topend power. But, 3" setup sucks for daily driving very little ground clearance. It scrapes on speed bumps, steep driveways, and going fast on slopey roads.
I only lost a 1 inch of ground clearance from stock. If it setup right you shouldnt have any problems
