Dual 2 1/2 inch or 3?!?!
Old Mar 11, 2012 | 03:13 AM
BLK93TA's Avatar
Default Dual 2 1/2 inch or 3?!?!
I have a full bolt on motor with 3.73 gears. Right one have a y pipe, but have a big hole in it and have wanted to dual it anyways... I plan on motor work soon so i know 3 inch will be the best. I def don't wanna oversize it but im not too worried about losing torque between my gears and 6 speed think i will be fine. Anyways, wanted to get your thoughts, THANKS!
Old Mar 11, 2012 | 03:17 AM
pillarpod's Avatar
3in no doubt
Old Mar 11, 2012 | 10:50 AM
96lt1m6's Avatar
I hae had 2.5'' duals w/ X-pipe for a few years and see absolutely no reason to do 3" without having a LARGE cam along with fully ported heads. unless you are using a supercharger 3'' is overkill.......jmo
Old Mar 11, 2012 | 11:58 AM
Ocala93TA's Avatar
I have 3inch and its awsome !!
Old Mar 11, 2012 | 12:03 PM
JUSTINSWS6's Avatar
3 inch it sounds louder and better.
Old Mar 11, 2012 | 12:35 PM
nitrous2fast's Avatar
You should go dual 2.5". Dual 2.5 will easily support what you can do with head cam LT1's.
Old Mar 11, 2012 | 03:42 PM
BLK93TA's Avatar
I plan on getting a LT1 hopefully sooner than later stripping it to the block and building it up as a 383 so 3 will be fine with that but i don't know how long thats gonna be. I just don't wanna drag this motor down in the mean time with my stock internals. But also don't wanna have to mess with my exhaust again
Old Mar 11, 2012 | 03:52 PM
Ocala93TA's Avatar
Before i did the cam work to the car I had complete stock motor with just a tune headers and 3inch true duels and it ran 13.6 on street tire believe me you wont hurt anything running 3 inch on stock set up
Old Mar 11, 2012 | 03:58 PM
1_MEANZ28's Avatar
3" u wnt regret it
Old Mar 11, 2012 | 04:09 PM
BLK93TA's Avatar
Sweet thanks for the info!
Old Mar 11, 2012 | 09:56 PM
tonskiguy's Avatar
Are we talking dual 3"? Will that fit?
Old Mar 11, 2012 | 10:35 PM
coolmanvette75's Avatar
I have 3inch duals and love them!
Old Mar 11, 2012 | 10:42 PM
IronOutlaw's Avatar
I went with 2.5" I think I would have had a hard time tucking up 3" with the way I routed my pipes.
Old Mar 11, 2012 | 11:12 PM
LT1's Avatar
LT1
I would recommend 2.5" setup.
I'm running 3" x-pipe to dual 3" muffler and 3" inch tail pipes, it sounds awesome and makes good topend power. But, 3" setup sucks for daily driving very little ground clearance. It scrapes on speed bumps, steep driveways, and going fast on slopey roads.
Old Mar 11, 2012 | 11:24 PM
jaycenk's Avatar
Do a hybrid if you can. Track rules you race at may play a factor in this and local laws on the street but some tracks require a "muffler" of some sort. Long tubes to 3" pipe to 3" E-cutouts reduced then after cut out to 2 1/2 out the back. much easier to rout and still get the free flow at the track but should be nice and bearable on the street depending on what muffler you run. I liked the system one of the members did with the dynomax crossflow muffler out back in the stock location with dual duals. cant rember who did it though. It was a convertible camaro I think.
Old Mar 11, 2012 | 11:35 PM
jaycenk's Avatar
Here found it. it was WRd1972's setup
https://ls1tech.com/forums/lt1-lt4-m...my-design.html
Old Mar 12, 2012 | 12:01 AM
93z383's Avatar
2.5 " is WAY MORE than enough and will support a ton of HP. Unless you plan on making more than 5-600rwhp 3" is overkill and will bring the issue of axle clearance... Most shops can't handle getting it to clear even with the panhard relocation, which lowers it down with adverse effects...
Old Mar 12, 2012 | 02:19 AM
Blk98Vert's Avatar
3 inch either dumped or under the axle. if you have a shop that remotely knows what they are doing you will be fine
Old Mar 12, 2012 | 12:47 PM
1961ba427's Avatar
The easiest to do set up I have seen replaced the back half of the ORYP and the intermediate pipe with a narrow X, dual 3" bullets, a pair of cut-outs, and a short Magnaflow type Y-merge. It had the cut-outs positioned to flow straight back if uncapped while the forked off side turned up to go over the axle, into the Y-merge. The Y-merge was welded to the single 3" over the axle pipe and from there back it was a normal catback. This system had no loss in ground clearance and when un-capped would give all the flow of any 3" true duals. Assuming you already have a decent 3" catback and an off road Y-pipe, you could buy the parts to build this for about $100.
Old Mar 13, 2012 | 04:15 AM
BLK93TA's Avatar
I am probably going 2 1/2, i was under the impression i needed the pan hardrod relocation to run dual pipes even 2/12 inch duals? Also what do you mean does it lower the actual pan hardrod? In a bad way?
