lt1 boost ngktr6 gap?
Old Mar 13, 2012 | 02:53 PM
95batmobile's Avatar
Default lt1 boost ngktr6 gap?
as title says what gap should i run for a 8lb rear mount system with a stock motor with tr6
Old Mar 13, 2012 | 03:28 PM
stuart4185's Avatar
i run .35, which is the factory gap i believe
Old Mar 13, 2012 | 03:58 PM
katz_2003's Avatar
I would run .35. Stock gap is .50 fyi
SexyTransAm's Avatar
factory gap is like .55
Old Mar 13, 2012 | 05:11 PM
great421's Avatar
My set up = 0.39" gap on NGK TR6 IX plugs
Old Mar 13, 2012 | 06:33 PM
stuart4185's Avatar
sorry to offend the factory chevy spark gap, i was refering to the NGK tr6's factory gap is set to .35.
Old Mar 13, 2012 | 07:23 PM
popo8's Avatar
I run a boosted application. Anything over .030 and I blow em out....
I run .028 on a 1 degree colder plug....(colder than stock that is.)
Old Mar 13, 2012 | 10:35 PM
lol ok so i guess there is some play with this? .35 seems to be successful with people... will the lower the gap mean colder the burn?
Old Mar 14, 2012 | 10:33 AM
bumppp.. lots of different number here...
Old Mar 14, 2012 | 11:28 AM
nitrous2fast's Avatar
what is your ignition setup?? that would be a large determining factor on what size gap you could run...
Old Mar 14, 2012 | 11:54 AM
all msd.. from the coil, wires, opti, 6al
Old Mar 14, 2012 | 12:54 PM
katz_2003's Avatar
Lower the gap means less chance of spark getting blown out. Bigger gap is better but too big will blow out spark. I don't think I would go over .40 but if you wanna try anywhere around 30-38 I think you would be fine. Just check them after running it and see how they look. You will tell in how the car runs if it's blowing out the spark.
Old Mar 14, 2012 | 01:59 PM
with the msd coil and the 6AL you could do .040. instead of running the TR6's you could run the BR6ef which is a non-projected tip plug and they resist blowing out more than the projected. Br6's have the same heat range but are non-proj. also less chance of cracking the porcelain... Just a idea to ponder...
