Lokar Oil Dipstick and AS&M/RK Sport Headers?
Guys,
I've had it with the stock dipstick tube as it doesn't fit right on my car and with all the damn bending I can't get it to bolt back up or fully seat right. I'd like to go the lokar route and I know they get hot as hell but don't care as I will check the oil with gloves. My question is there anyone here that has the AS&M/RK Sport mids on their car with a Lokar as where they are typically mounted (between #4 and #6) there is little/no space with these headers due to the primary. Any pics would be helpful or suggestions.
I have the Lokar with RKsport headers, I ran it for a long time just free standing between the #6 & 8 primaries then used a short sheet metal tab to bolt it to the forward bolt on the #8 primary.
You are right about it getting very hot, you learn quick not to touch it till it cools down for a while.
The dipstick tube installation was a terrific pain in the *** with my old RK sport headers.
To make things much easier, I cut the original mounting bracket off of the tube and JB welded the tack weld holes that remained in the tube to seal them off. I then fabbed a separate bracket out of thin gage 1/2 steel and bent it in the shape of a J to form a clamp. This bracket bolted to the block and captured the dipstick.
This allowed me to loosen the bracket and easily slide the dip stick tube in and out with no issue.
