new 357 rich or lean?? smells like gas
Idk what is going on with my car ? I have a ses light on the dash. also have an plug in the engine bay not plugged in.
The car starts up fine, acts semi normal considering i started the build 2 yrs back (ran out of money) and only have a pcm tune. But it smells like gas bad and once you shut off the motor it will need 10-20min sitting before it will start back up.
Batt/alt/starter, all newer (1-2k, 2-3yrs old) IDK if its too rich as is flooded or im too lean? the car has new O2's in it, but that have been sitting around for 2yrs along with the car.
I have been working with a older mechanic. I goto his shop to work on the car, he helps me when im stuck, i use his tools, etc.... but i dont really trust when he gives me LT1 advice.
I have a purple plug on the right by the driver side header that is unplugged. 890% sure, its the secondary air pump plug but not sure?? ive accounted for everything else.
car does not have egr, air, oil cooler, washer fluid res., horn, fog light, etc. but i do have it all this **** tuned out so i dont think it should make a difference any way..??
whats going on here??.......i ran out of money on this build and it sat for 2yrs. its just getting MOST of the bugs out. 270 miles on the 357 so far.
fuel pressure at ldle is 45 psi, just the key turned is 39
it is throwing code 43, ESC module. But when i look it up its says its suspension related??
I thought it would of been electronic spark control....
