$$2000 Lt1 build help
Old Mar 21, 2012 | 12:45 AM
bm19's Avatar
Default $$2000 Lt1 build help
my dad just told me i got 42000 to $2500 to use for my camaro..heres my car 94 Z28 M6 has 210K miles..well taken care of and parts replaced but the simple stuff nothing major like heads, engine, ect...the rear is stock, tranny stock, and suspension stock....i want to put it in the engine...am i better off doing a bottom build to 355 or a topend build with LE2? Id greatly appreciate the help since you guys know alot more than me lol any questions just ask...thanks!!!
Old Mar 21, 2012 | 01:07 AM
Catmaigne's Avatar
You aren't going to see much of a difference with 5 extra cubes and a stock top end. Go LE2.
Old Mar 21, 2012 | 08:56 AM
sandman2100's Avatar
42000??
SWEET!
$2500, I'd go H/C as mentioned above.
Old Mar 21, 2012 | 09:39 AM
IronOutlaw's Avatar
I don't think I would modify a 200+ thousand mile motor. If you could squeeze out enough money for a cam only 355 I would do that.
Old Mar 21, 2012 | 10:23 AM
Skipped over that part. Save up, do it all in one shot.
Old Mar 21, 2012 | 11:59 PM
englundjd's Avatar
make yourself a 355 with a stock machined crank, new rods and deffinatly new pistons/rings, and at that mileage a new timing chain would probably be good. see if you can find a cheap used lt4 hotcam to throw in it if you want more power to go with it
Old Mar 22, 2012 | 07:55 AM
robsquikz28's Avatar
I have le1 heads for sale. Also lt4 le1 heads and the lt4 intake for sale. Lmk
Old Mar 22, 2012 | 12:28 PM
David_94Bird's Avatar
If op doesn't want, than I'll check em out.
pm sent
Old Apr 3, 2012 | 02:05 PM
lt1needingboost's Avatar
Default budget
definately do heads and cam maybe stall and tune if u can get some used stuff like robs.
Old Jul 9, 2012 | 07:04 PM
LowestIntentions's Avatar
RobsQuik, do you still have either of your heads for sale?
Old Jul 9, 2012 | 08:56 PM
trilkb's Avatar
Im with other people saying not to mod a 210k mile engine. 110k is one thing, 210k is another. But hey you could do a compression check and if its all good then thats something. You still risk cam and crank bearings being worn though. If you put the 2k into mods, the motor will probably grenade, if you put 2k into a motor, you wont have any mods, but the motor will be ready for them down the road.
Kind of a tough scenario man. You can find some lower mile used lt1's, but you risk them being bad and not knowing it.
In the end I think the smart thing would be to do a rebuild. When you do the mods, you are gonna be driving the car harder, garuentee it! A 210k mile motor probably wont like that either!
Old Jul 9, 2012 | 10:35 PM
defaultexistence's Avatar
Le2 topend and polish/balance the crank,new rings,bearings,OE timing chain, melling 10554 oil pump, stall,tune . Minimum or your pissing into the wind and will end up unsatisfied.
So save another grand and have a parts/grocery getter on reserve.
Old Jul 10, 2012 | 12:45 AM
esoteric18's Avatar
Rebuild, polished crank and new pistons, bearings, rods, all seals and gaskets. Should have enough after that to maybe go cam only and room for future mods.
Old Jul 10, 2012 | 12:52 AM
turtle93's Avatar
Might be different but why not buy a parts hauler should be able to find a cheap 4 banger car or truck for around 1000 then do a 350 rebuild and add a lt4 hot cam or some spray and that way when your ready you can build a nice motor and not have to walk while your car is down if this isn't an option I would say freshen up the old 210k motor
