HD water pump LTx ????
The electrics do flow more at idle..........................when the engine is making no heat to speak of.
http://www.meziere.com/ps-813-781-wp118hd.aspx
I am not saying electrics are without purpose or bad, just urging some vague understanding which is usually quite unwelcome.
The 66gpm figure I spoke of is from an SAE document on the LT1 cooling system, again the electrics are all freeflow rated.
For a drag car the ability to cool down between passes certainly makes an electric worthwhile, for a roadrace car they are often found insufficient and for a street/strip car well you have to decide if the .1 is worth the greater possibility of sudden complete coolant flow stoppage be it from the pump motor dying or an electrical fault. The mechanical will usually weep and let you know well in advance so you can change it before it really fails.
I eventually put an electric on my car for the .1 at the track, but even in 40degree weather the car runs warmer on the highway than in town, even with cool 70mph airflow the electrics are just starting to lose control. I can cruise for a 2.5hour drive home and it wont overheat or anything but the temp will come down once I get near home and speed drops to 35mph.
I have a LT1 Corvette, and I agree with 96capricemgr. I want to switch back to a stock pump. It's exactly as he says, temp at idle is great but past 2500 rpm the temp will go up to the hatch marks and when I step on the pedal the needle goes beyond and the water boils in the surge tank.
I wont claim the stock pump is perfect the road racers do find it to cavitate at high rpm. Stewart's pump(real racing pump) teased us with the idea of an improved LT1 pump for awhile but as with so many other LT1 R&D ideas it never flew.
Part of me wonders about modifying a nicer EWP impeller for use on the stock pump. The stock impeller certainly leaves some room for improvement, what I don't really know though is how fast the electrics spin and if the impeller would work decently over the mechanical pump's rpm range.
I haven't seen anything about anyone really playing with the guts of the stock pump to try and improve it. I know one guy who welded the impellers on because he would twist them off but it is a 1500hp car, the rate of acceleration(Pump has to accelerate the water within the system) there is beyond what the rest of us will see.
A stock one will work fine for you as stated. Some have to go to an electric for other reasons such as using double roller timing chains which can't drive the stock water pump shafts.
My springs are pretty stiff with 560 lbs. Hope I wont get any problems going back to a single roller.
are you sure it good?
assuming its a 180* incoming temp. a drop across the core that big is a flow problem. first thing i would do is check voltage drop to the pump. then get a set of moroso water restrictors. put the smallest one in and check your temps incoming and out going. then move to the next size up. and keep going though them one by one. we look for a optimal 10* to 15* differential from inlet to outlet. if there is no or minimal change from the smallest to the largest restrictor. you need to pull the radiator and have it flow checked.
