HD water pump LTx ????
Just all of a sudden as I was cruising along at 70mph (returning from a 30 mile visit to my inlaws) the temperature gauge went from 1/4 to pegged instantly. I pulled over as quick as I could. Once I got the car towed home the next morning I pulled it up on ramps and the waterpump was leaking out the weephole - again, after the damage was done. I replaced the pump and thought nothing of it because I didn't get any white smoke or lost power indicative of a blown head gasket until I went to start my car and it was hydrolocked
So I don't put any more trust in a mechanical over an electric failing without warning. In fact I should look up how to wire a warning device with the electric...
Next will be the radiator, but I don't think this is the cause because it's my second one. After I noticed the engine was still getting too hot I swapped to a bigger one a few years back. I only drive about 1k miles a year so I don't think it's clogged, but this also I will check.
The pump was on the car for just about 13k miles.
Since you didn't diagnose it maybe the head gasket went first? Cooling system over pressure made the seals in the mechanical pump fail???? That could cause a leak there that would mislead you to blame the pump.
It is possible to have any mechanical or electrical device suddenly and completely fail, just MUCH more common with the electric pumps than the mechanicals, the vast majority of the time the mechanicals weep for an extended period and the driver notices interruptions in the power steering at low speeds with sharp turns like in parking lots and the driveway.
I never said do not diagnose a problem, what I said was the raised cruise temp is typical of the electric pumps so there is no problem to diagnose.
If it were actually overheating or creeping up at idle or something then that would be evidence of a problem.
I have been driving it around in the 98-107 degree heat and it never got over 170. The needle hardly moved off of 160. That is with no front air damn under the car and 70+ mph runs down the high for 30 miles at a time.
