Ported Intake, where to get done
Old Mar 22, 2012 | 08:26 PM
F0x Slaughter's Avatar
Technically any cam yes can be ran on stock heads but the it would be a serve choke to the cam.
Old Mar 22, 2012 | 08:29 PM
RamAir95TA's Avatar
...wat.
Puck's Avatar
Just like the 847 you listed.
Old Mar 22, 2012 | 08:32 PM
But then the stock heads would choke the cam. Yea the GM847 is a bit much for a stock head but guys are running them. Usually see the CC503 though.
Old Mar 22, 2012 | 10:28 PM
FAD2BLK93's Avatar
Can anyone tell me where or part number of 58mm tb gasket? Thanks
Old Mar 23, 2012 | 07:10 AM
lildemars09's Avatar
BBK Performance 1584
Old Mar 23, 2012 | 07:14 AM
Yes I realize I can run my stock heads on a cam but i lose power like crazy, so i either get them machined or I just buy new heads. I know the things I have to change and all I just don't know which parts I need, like sizes and all that go with the cc503. I read part of the sticky on what parts i will need.
Old Mar 23, 2012 | 07:38 AM
Alright real quick since you guy are smart, and I do not want to make another thread, does your oil pressure gauge bounce around a lot, Mine goes stays up when cold but when its warms up, every time I hit the gas it goes up and then when I stop it goes to zero and then the check gauge light comes on and it shuts off every time i hit gas, weird I know. Its hard to explain it on here.
Old Mar 23, 2012 | 07:44 AM
and no the oil pressure sending unit isn't bad since I already changed it, while installing my stall i crushed it on the firewall, ha silly mistake.
Old Mar 23, 2012 | 09:13 AM
bufmatmuslepants's Avatar
That would be your oil pickup tube has falled off. Common problem. Next time you change your oil look in the hole and it will probably be sitting in the bottom of the pan.
Old Mar 23, 2012 | 10:15 AM
Really so I have to pull motor to fix it? so i need to fit it before i keep driving it correct?
Old Mar 23, 2012 | 10:45 AM
  #32
RamAir95TA's Avatar
You should fix it ASAP. Anytime the pickup for the oil pump is not submerged in oil your bearings are no longer receiving oil - not a good thing.
Old Mar 23, 2012 | 10:56 AM
  #33
jasonz28camaro's Avatar
you can take the manifold off in like 10 minutes
Originally Posted by Puck
There is a write up somewhere.
What I did was mask off the engine bay with plastic bags, then stuff lightly oiled rags inside the intake holes. I marked it using the 58mm gasket, then dremeled it all out. I then pulled out the rags, which caught and removed the shavings, and shop vac'd everything before removing the garbage bags. I should have a picture saved somewhere...
...Yep, here it is:
Old Mar 26, 2012 | 09:58 AM
  #34
Well I was told by a guy who built his LS motor and his dads LT1 (conversion to LS) he said his dads car does the same thing and everything on the cars new. he said its an LT1 thing with the gauges
Old Mar 26, 2012 | 11:23 AM
  #35
Puck's Avatar
He is incorrect.
What you are describing is usually a dropped pickup.
Old Mar 26, 2012 | 11:43 AM
  #36
AChotrod's Avatar
X2!!! I would not want 0 pressure ever!
Old Mar 27, 2012 | 04:05 PM
  #37
Wyocattech's Avatar
The pick up falling off is why i got my car cheap! Holes in the oil pan from a spun rod bearing from lack of oil. 0 psi is the absolute worst thing for an engine. As for a cam stay away from the gm 847, and cc306. CC503, or a custom grind from AI or LE would be the best. Tell them what bolt ons you have and your driving style and they will make the right choice for you. Also any cam can be ran on a stock headed engine. With any cam change its REQUIRED to change the valve springs to the reccomended for the camshaft.
Old Mar 27, 2012 | 04:13 PM
  #38
WS Sick's Avatar
^ You do not need to touch the heads at all for a cam swap.
What about rocker adjustment........he he
Old Mar 27, 2012 | 08:19 PM
  #39
Hm, well considering to remove a cam you must remove rocker arms, then the push rods, and pull the lifters. None of those parts are the heads. They are the valvetrain.
Old Mar 27, 2012 | 10:43 PM
  #40
WS Sick's Avatar
Just having fun.
