Ported Intake, where to get done
Old Mar 28, 2012 | 06:25 AM
  #41
F0x Slaughter's Avatar
Just checking sir.
Old Mar 28, 2012 | 07:36 AM
  #42
SS RRR's Avatar
Village Troll
Originally Posted by RamAir95TA
IMO it's not worth the risk to port the intake with it still on the engine. No matter what kind of precautions you can take some shavings will always make it through. But that's just me.
Nope. Not just you.
Old Mar 28, 2012 | 01:14 PM
  #43
lildemars09's Avatar
alright so whats the best way to check to make sure it has fallen off? I dont want to pull everything off and then figure it wasnt it (you guys could be right but I would hate to do all of that and figure it wasnt that)
Old Mar 28, 2012 | 01:20 PM
  #44
1961ba427's Avatar
Originally Posted by bufmatmuslepants
That would be your oil pickup tube has falled off. Common problem. look in the (oil drain plug) hole and it will probably be sitting in the bottom of the pan.
Earlier in this thread.
Old Mar 28, 2012 | 01:32 PM
  #45
now what if I cant see it through that little hole though? I remember him saying look through the hole.
Old Mar 28, 2012 | 01:35 PM
  #46
1961ba427's Avatar
I think you will be able to see it okay...especially if you poke around in there with a piece of clothes hanger or something safe like that you will feel it laying in there. You can also remove the low OIL LEVEL switch and have a bigger hole to look through. If all else fails, borrow a Bore Scope. Those things are the bomb!!
Old Mar 28, 2012 | 01:52 PM
  #47
I think you will be able to see it okay...especially if you poke around in there with a piece of clothes hanger or something safe like that you will feel it laying in there. You can also remove the low pressure switch and have a bigger hole to look through. If all else fails, borrow a Bore Scope. Those things are the bomb!!
here's a stupid question wheres the low pressure switch? I will have to try that out, thanks for the good info
Old Mar 28, 2012 | 02:01 PM
  #48
1961ba427's Avatar
HAHAHA...you caught me. I meant to say "low oil level switch". sorry
Old Mar 28, 2012 | 02:14 PM
  #49
Alright ill have to do that, those break easy when takin out? Mine prolly haven't ever been changed
