Ported Intake, where to get done
Thanks
Take your time and do your research and use different car Forums as your free source of information. You have already spent some money on questionable mods, but doing your homework will save you more costly mistakes in the future.
What I did was mask off the engine bay with plastic bags, then stuff lightly oiled rags inside the intake holes. I marked it using the 58mm gasket, then dremeled it all out. I then pulled out the rags, which caught and removed the shavings, and shop vac'd everything before removing the garbage bags. I should have a picture saved somewhere...
...Yep, here it is:
...Yep, here it is:
A .540/.545 lift (random numbers to show difference) at 1.5 will equal .576/.581 on 1.6.
.540 / 1.5 x 1.6 = new lift
so lift divided by rocker ratio times the new rocker ratio gives you the new lift.
How much does a package like this cost with everything?
