It lives
Old Apr 7, 2012 | 09:46 PM
  #101
SS MPSTR's Avatar
Nice times, man.
Old Apr 7, 2012 | 09:53 PM
  #102
gregrob's Avatar
Thanks man
Old Apr 7, 2012 | 10:49 PM
  #103
1badzee's Avatar
Bad friggin' *** man!
Old Apr 7, 2012 | 10:58 PM
  #104
BADHAWK51's Avatar
Nice !!!
Old Apr 7, 2012 | 11:06 PM
  #105
Bersaglieri's Avatar
And I thought my 5500ft DA was hurting my times, well done.
-Dustin-
Old Apr 8, 2012 | 03:01 AM
  #106
gregrob's Avatar
Wink
Originally Posted by Dave357LT1
Why 6700? Where does ur cam peak at? What would those numbers translate to at sea level?
I need to get it on the dyno to tune it. But I can tell you it will bury the tach and be pulling HARD. It pulls harder at 6700+ than 6K
Old Apr 8, 2012 | 03:20 AM
  #107
Hit em Up's Avatar
Man I've been following this build and gotta say those are great out the box times!! When you factor in DA/tune/60s with upgraded suspension it's a lot left on the table!!:
Old Apr 8, 2012 | 03:32 AM
  #108
gregrob's Avatar
Thanks man. A lot of people dont understand that, but todays runs were some very rough shakedown passes.
I can push the tune a lot more, I have rev limiter issues. The launches are embarrassing because the stock suspension does so much goofy stuff the car is all over the place.
The only weight reduction is stereo stuff, front bumper support and washer tank as well. Plenty to go there.
It's certainly a work in progress, but I'm going to take care of this bottom end and progress toward a more drag oriented setup, that's still very streetable when desired.
Lightweight brakes, tubular front end, solid roller, better intake mani, full AFCO suspension, some more mild weight reduction, fine tuning the engine and chassis. Faceplate the trans, maybe a better clutch setup (soft loc).
It still has a lot on the table. I feel its very respectable for a .030 over LT1.
I need to build a stroker one of these days and make some real power
Old Apr 8, 2012 | 03:46 AM
  #109
gregrob's Avatar
Old Apr 8, 2012 | 04:19 AM
  #110
Hit em Up's Avatar
No doubt very respectable!!!! Once my new combo is done I will post progress as well.I just switched to higher cr Je dome/solid roller/single plane/carb setup with Afr227 comps.I no you will get it dialed in and cya at the shootout
Old Apr 8, 2012 | 08:42 AM
  #111
SS RRR's Avatar
Village Troll
Originally Posted by gregrob
Miss that easterly scenery from that point of view. Good show on the numbers. Would love to see a time slip.
Old Apr 8, 2012 | 09:05 AM
  #112
Rob94hawk's Avatar
6700 on a hydrolic? Damn that's impressive! Must be one hell of a cam.
Old Apr 8, 2012 | 12:16 PM
  #113
Wicked94Z's Avatar
nice job bud! 1.899 60' on motor? **** you have a half second right there
Old Apr 8, 2012 | 01:07 PM
  #114
BADHAWK51's Avatar
Looks like your going to need a drag bar soon. I think I see it starting to twist just a bit.
Nice pic.
Old Apr 8, 2012 | 02:45 PM
  #115
BizZzatch350's Avatar
Moderator
Your doing it...right. Congrats man, cars killer. Running better then most folks stuff at sea level let alone that moon walking air.
Old Apr 8, 2012 | 03:31 PM
  #116
gregrob's Avatar
Smaller than some of the donkey dick most people run. 232 238 .629 lift 112 LSA
Old Apr 8, 2012 | 03:32 PM
  #117
gregrob's Avatar
Awwww SS don't you believe me?
Old Apr 8, 2012 | 03:40 PM
  #118
gregrob's Avatar
Thanks man. Its definitely cool to see it start to come together.
Old Apr 8, 2012 | 04:09 PM
  #119
SS RRR's Avatar
Village Troll
Now now there's no reason to make a thing. I like to see all times and mph throughout the run is all. If it's that big a deal forget about it.
Old Apr 8, 2012 | 04:36 PM
  #120
gregrob's Avatar
It's cool. Ill post the 11.04 slip on the .062 jet.
Believe it or not, my fastest pass of the day was the very last pass, and they didn't print it!
I was pissed, it is on video though.
I think after this shakedown outing I need a taller gear, so its going to get probably a 3.73 and light weight spool soon.
