muffler selection help
Old Mar 27, 2012 | 03:08 PM
tricked94camaro's Avatar
Default muffler selection help
getting the final pieces together for my v6 to lt1 swap. looking to do a cheap exhaust and ive decided to go with dumps before the axle. need help selecting a pair of small mufflers. i dont want it too loud as i will have my 2yr old in the back but i do want it to sound muscular at higher rpm's. open to suggestions. thanks.
Old Mar 27, 2012 | 03:44 PM
nomoneyz's Avatar
I don't think its possible to have quiet dumps. Why not just run a standard y pipe and catback?
Old Mar 27, 2012 | 03:45 PM
no money
Old Mar 27, 2012 | 03:54 PM
sandman2100's Avatar
Headers or stock Y pipe? Shouldn't cost too much to run a single pipe all the way back and a muffler. Search here or Craigslist and see if anyone is dumping a stock axle back system.
Old Mar 27, 2012 | 03:58 PM
i was going to make it myself using the stock manifolds then later when i work all the bugs out and have it up and running 100% ill put on lts and catback when i have the $$
Old Mar 27, 2012 | 03:59 PM
VinR1's Avatar
Look for the single in/out Flowmaster system with the 30-series muffler. should be able to find the complete system for around $250. I have it with Mac mids and no cat and its quieter than stock on the inside with no drone or resonance whatsoever. Outside its deep and tough without being obnoxious. I ride with my 2yr old and 7yr old all the time
Old Mar 27, 2012 | 04:00 PM
ahritchie's Avatar
Originally Posted by tricked94camaro
no money
Cherry bomb glasspacks! ***Warning*** your child may experience hearing problems and or temporary deafness.
Just look on craigslist for a used cat-back or get a cheap-o jegs cat-back
http://www.jegs.com/p/JEGS-Performan...60947/10002/-1
i dont have $250 to spend. im laid off, sitting in the hospital for 3 days and have a family to feed
Old Mar 27, 2012 | 04:02 PM
gregrob's Avatar
Purple hornies FTMFW
Old Mar 27, 2012 | 04:05 PM
lol no glasspacks
Old Mar 27, 2012 | 04:09 PM
Come on there has to be something quiet enough to silence 4 cylinders!
Wyocattech's Avatar
Use a magnaflow round muffler. They are fairly quiet. Be sure to use a turn down though. They will still drone at cruising speeds.
Old Mar 27, 2012 | 04:12 PM
makin turn downs for sure. not worried about drones as long as its not too loud
Old Mar 27, 2012 | 04:53 PM
Magnaflow at 2,000 RPM will drone. Flowmaster 40 series, drones louder.
Old Mar 27, 2012 | 04:55 PM
Any other options?
Old Mar 27, 2012 | 05:15 PM
IronOutlaw's Avatar
In running magnaflow 4x9s and an x pipe dumped at the axle. It drones less than my old flowtech catback.
Old Mar 27, 2012 | 05:24 PM
96RamAirTA's Avatar
I have a axel catback off a 97 formula
Old Mar 27, 2012 | 05:28 PM
VinR1's Avatar
I have a full system with a glasspack, single turndown, 2.25" off a 97 v6 firebird you can have, just pay shipping...
Old Mar 27, 2012 | 05:53 PM
thanks guys but kinda wanna wanna build my own
Old Mar 27, 2012 | 06:29 PM
trilkb's Avatar
Magnapacks are not quiet. I know that much. I ran 2 magnapacks on a 3.9L v8 Lincoln LS for awhile, hated the sound.
Moroso spiral flows are quieter then magnapacks.
If money is so tight, The best bang for you buck would probably be a used cat back. Hell, you might be able to find a stock catback for dirt cheap. You could run that until you have the money. The Long tubes and no cats will bring out more sound. A stock cat back will kind of choke the car but atleast you know youll be getting an end result of "quiet" lol
