I've been defeated by my LT-1, Please help..REWARD
Old 03-31-2012, 09:34 AM
  #41
95batmobile's Avatar
sounds like a cat.. had it happen to my jeep and my car. it would hit a certan rpm and would just get stuck.. got worse as the days went by.. first day i could go like 70 then by the 3rd day i was stuck at 50..
Old 03-31-2012, 09:52 AM
  #42
Gojira94's Avatar
Originally Posted by gregrob
Agree, 550 is stock on some calibrations for an auto.. whoever said it can't be is misinformed.
I would start with a stock tune just to be sure.
And definitely pull the cat off...
True- my 94 A4 stock tune was set for a commanded idle of 550. Thought it was wrong until I did some checking.
Old 03-31-2012, 09:56 AM
  #43
stuart4185's Avatar
Grazi, where do you live?
Old 03-31-2012, 11:20 AM
  #44
grazi's Avatar
im in new jersey
Old 03-31-2012, 01:16 PM
  #45
stuart4185's Avatar
damn, i messed up thinking you had an OBD2 car, whats the cost to get a reflash from PCMforless or similar? just take it back to stock, or slightly better optimization
Old 03-31-2012, 06:51 PM
  #46
grazi's Avatar
So I think my first route is Im going to cut out my cat and install a high flow cat...I was thinking about doing a test pipe but I dont want to get too much smell and if I keep the car til next inspection, I dont want to deal with the hassle.....What do you guys reccomend for a good high flow cat. Seen a couple on ebay for like 40 bucks...Stupid question. Is the stock Y pipe going to be 2.5" for the LT-1?
Old 04-01-2012, 09:49 AM
  #47
cookietime's Avatar
Before you cut the cat off, un hook the flange behind the cat, 4 bolts, and check if any exhaust is coming out. that should help determine if the cats clogged or not. If it is clogged you can hollow out the cat for now, until inspection time.To save a few bucks.
I needed a new 1 and opted for the magnaflow one, and passed nj sniffer testing.
http://www.ebay.com/itm/MagnaFlow-Di...c10f81&vxp=mtr
Old 04-01-2012, 10:01 AM
  #48
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
You might also have some metallic flakes coming out the rear of your exhaust if your cat has collapsed, or is clogged. This happened to me a few times, but my car was pretty much undriveable in each instance.
Old 04-02-2012, 05:09 AM
  #49
4K+Converter's Avatar
I've been fighting a similar problem with my mother's 95 Mark VIII, except with a random miss everywhere. First I suspected bad gasoline and I've worked my way down to some sort of sensor problem.
I yanked a few fuses to deal with anything PCM related and the car came back to life temporarily. The miss was gone, and the car even had more "vacuum." I say this because on cold start when the idle rpm is high, it really starts moving when my foot comes off the brake. Additionally the brakes are way more touchy now, there is a small threshold where the brakes are off, then on. This is the way it was before the problem. But a few days later it started hardcore studdering again, but was fixed with yanking the fuses again. Next time I'm going to yank one fuse at a time to see which system the miss is involved with.
My advice is to pull the PCM fuse and let it forget all its temporary data. I think 15 minutes is all you need, although I haven't dealt with an LT1 car in a long while. Although I don't know what sort of involvement the PCM has to do with your problem. The good news is that testing it is free and if it resolves your problem temporarily, it'll give you another clue to whats going on.
Old 04-02-2012, 02:24 PM
  #50
93v8clone's Avatar
how old are o2 sensors ????? mine did same a so/p and i hanged em and ran great after
Old 04-02-2012, 02:39 PM
  #51
Mississippi's Avatar
Mine just did this a few months ago. Its the cat. Gut the cat and then go have fun. If you live in a state that requires emissions bs then replace that ******. It definitely sounds like a cat for sure. Don't do like I did and change an optispark when you don't need to.
Old 04-02-2012, 08:21 PM
  #52
Coyotesa's Avatar
Any updates?
Old 04-02-2012, 08:36 PM
  #53
quik95lt1's Avatar
happened in my gto i blew the cat out of its housing and it got lodged in my x pipe........car didn't misfire but felt like it was down about 200 hp lol figured it out immediatly when i saw the little pieces of tin foil shooting out the back of the car lol
Old 04-03-2012, 03:38 PM
  #54
grazi's Avatar
I actually havent had the time to get under there and do it yet. With the babies I have about 1 hour per month of free time. Im excited to see if its the cat though. thx
Old 04-03-2012, 03:51 PM
  #55
ZGOBYBY's Avatar
Good luck man, you are in good hands around here.
Quick Reply: I've been defeated by my LT-1, Please help..REWARD
