Canton 242T oil pan users
The only problem (so far?) I've had with mine is that I cannot run a dipstick with it. That may be the pan or my main caps (machinist decided to use traditional SBC caps) or a combination of the two.
Other than that it has been fine. I don't have any leaks and I have so much oil pressure I'm surprised the pan doesn't blow off :p
I ground it up slowly with my dremel until it was basically nothing and it broke off in the pan
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
No problems.
![Hijacked!](https://ls1tech.com/forums/images/smilies/myhijacked2.gif)
