383 Rebuild Advice
Unkown brand CNC ported heads 57cc chambers
Mystery baby cam
Callies forged crank
SRP -16cc pisons -.015 in the hole
Ported intake
Full bolt ons
12 bolt with 4.10 gearing
6 speed car
The car runs and drives fine but the oil pressure will drop to 0 for a second or two every once in a while after a WOT pull or after coming off the freeway and immediately coming to a stop on the off ramp. With that build and a super thin head gasket i could get a maximum of about 10.5 to 1 comp ratio from my crappy calc. I'm debating on just throwing it back together and calling it good or tossing in a new set of slugs and having it rebalanced and new bearings etc for peace of mind. I guess I'm just trying to justify rebuilding a pretty good motor haha. Could it just be a high volume oil pump emptying the pan or something? Also how much fun am i leaving on the table by leaving the comp ratio that low?
Thanks for any advice!
With the probably loose pickup you can't go run it now so if you don't know how it performs now is NOT the time to.
It would just help establish how much has to change to get to a goal.
