Dart Heads vs A.I.TrickFlow Heads
#41
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
That article was bashed and discredited when it released by people complaining that they didn't re-tune the car after every head swap.
Personally, I thought it was a great comparison - just wished it had some other common heads as well - namely the Comp 195s, AI 200s, and LE3s.
At least we all agreed that the Edlebrock heads are junk
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
#42
What I don't understand, is surely the companies buy a set of the competition out there and try to best those? Why would you put something on the market that is markedly inferior to what your target customer could choose instead.
#43
As mentioned, I expect to exceed my 470 RWHP by a fair bit next time around, but even if I don't--how many hydraulic 355's do you know of that make 470 RWHP? 400+ lb-ft torque?
When most stock cube builds are considered successful if they exceed 400 RWHP and anything over 420 will have you re-posting their dyno sheets all over the internet, I have a hard time believing you'd be so ho-hum about my results if my heads were a different brand.
If it's really an "'objective' ho-hum," based upon data, please provide examples of hydraulic 355 LT1's that do really impress you.
And if you're not impressed with Brady's build, it's a free country I guess. Personally I don't feel right badmouthing a guy's setup when he's about 10 times as fast as me. There are probably quite a few kids in 15 second Hondas that "aren't impressed" with your car either, but how much should their opinion matter to you?
540 RWHP through a 9" without being fully tuned, 10-flats in less than ideal conditions is impressive to me regardless of the brand name stamped on the heads.
There are two LT1 data points, off the top of my head. It may not be many but we have a pretty good average result going so far.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
#44
So Jon, what yo uare saying is, people who bash Dart heads on an LT1 have never really seen what they are bashing, OR, they have seen untouched "As-Cast" heads on the car which of course will not perform up to the standards of AI or LE, BUT if the head is ported properly by someone who knows what they are doing and set-up properly, it has out-performed them all as far as stock cubes go? I just wanna make sure I interpreted that right haha
What are the chances that you could get us some specs and flow numbers for your heads the next time you have them off the car?? I would DEFINITELY like to see that! But I will admit, I was STOKED to have 411 RWHP and 393 RWTQ out of a 357 with LE2's. 470 out of a 355 is a damn good number regardless of how you got it or what brand you are using!
#46
A.I. 215's are running around $2600 fully assembled and shipped. I don't really want to break that number if I can avoid it, but depending on what I figure out, I may be willing to flex a little bit if the power gains are worth it.
#47
Also, my setup is far from optimized. It really shouldn't be hard to beat it, it could be done with several different heads. Just because I haven't heard about it doesn't mean it hasn't happened. I plan to beat it myself with the same heads by optimizing the things around them a bit better. That said, I do think my results are pretty darn strong for the first dyno after just slapping things together. Strong enough there should be no doubt the heads are capable of big power (as if Brady's results didn't already show that).
And I can guarantee you one thing, following the setup most recommended here for such a build, the cookie cutter stock ported heads and intake setup isn't going to stand a chance.
Like I've said though, these are but one example of a really well done head, there are plenty of others. These will be way above your $2600 number, but there are some choices that should come closer and are still really good.
#49
Would you like to see an 800 HP dyno sheet of one of those?![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Personally I like seeing all of the different builds, and the parts that guys use to break from the mold.
