Programming help please
Old Apr 8, 2012 | 09:30 PM
bc4850's Avatar
His computer is running windows 7 as well. It looked like it installed correctly on the computer but who knows that may be the problem. I cant do it on my computer because its a mac. he is supposed to get on here in a little while. Im just trying to get as much info as I can right now to possibly figure out what went wrong.
Old Apr 8, 2012 | 09:31 PM
F0x Slaughter's Avatar
When you installed the program did you right click on properties and tell it run compatibility with Windows XP?
Old Apr 8, 2012 | 09:34 PM
bc4850's Avatar
Im pretty sure he did but I wont swear to it
Old Apr 8, 2012 | 09:35 PM
bc4850's Avatar
the program worked until we tried to read the pcm and it just would not communicate it would just say cannot find pcm
Old Apr 8, 2012 | 09:36 PM
If I recall when you don't the program will open but won't function. Don't quote me on that.
I would probably just uninstall it, reinstall it by following the directions on the CD for Windows Vista and 7 install, then try again.
Do you have the OBD2 connector?
Old Apr 8, 2012 | 09:47 PM
bc4850's Avatar
Yes he already had the obd2 cable. What is the switch on the box for?
Old Apr 8, 2012 | 09:54 PM
I believe its to switch between OBD1 and OBD2 connector. I never touched mine. Mine is set to the setting closes to the wire coming out of the box. So the inner setting.
Old Apr 9, 2012 | 03:34 AM
chas010's Avatar
Say you and your mechanic get the pcm to communicate, what changes are you planning on making?
Old Apr 9, 2012 | 04:14 AM
bc4850's Avatar
haven't tried it yet hopefully later this afternoon
Old Apr 9, 2012 | 11:59 AM
bc4850's Avatar
Also are there any files out there to go by? Just something to base my tune off of?
Old Apr 9, 2012 | 02:12 PM
chas010's Avatar
Thats where i was going, its kind of a steep learning curve with this software. You could possibly do more harm than good.
