Programming help please
Old Apr 8, 2012 | 08:24 PM
bc4850's Avatar
Default Programming help please
Ok I now have my car back and it needs to be tuned. It is a 95 z28 so I ordered the tunercats program to tune it with and for some reason my car has an obd2 computer and obd2 plug. So needles to say I cant tune my car. I have already paid $80 more for the files for the obd 2 but now I need the program for obd2. Any suggestions? I have already spent alot of money and cant use it!!!
Old Apr 8, 2012 | 08:28 PM
ZFreie's Avatar
Unless its a different pcm in the car, you do not have an obd2 pcm. I also have a 95 and it uses the obd2 connector but is still obd1.
Are you SURE its an obd2 pcm? How did you go about checking?
Old Apr 8, 2012 | 08:33 PM
bc4850's Avatar
I am sure it is an obd2 pcm I have tried to use the tunercats software and it would not work and the mechanic looked at it and he also said it was an obd2
Old Apr 8, 2012 | 08:37 PM
bc4850's Avatar
I am so confused and frustrated on this right now, Im still hoping it is an obd1 what is the best/easiest way to tell?
Old Apr 8, 2012 | 08:39 PM
ZFreie's Avatar
Explain how tuner cats didn't work? Also, what reasoning did the mechanic give for it being a 96+ pcm? part #s?
The more info you can give the better, I'm no expert but willing to dig for info.
Edit, what is the part # on the pcm its self
Originally Posted by shbox
Look on your computer and see if you can find any of these service numbers:
93=16159278 OBDI
94=16188051 OBDI
95=16188051 OBDI
96=16214399 OBDII
97=16242921 OBDII
Thanks shbox!
Old Apr 8, 2012 | 08:49 PM
bc4850's Avatar
The tunercat would not ever recognize nor communicate with the pcm. The mechanic is the one that is going to be doing the tuning and has been trying to figure it out. Im not sure of what his reasoning is but he usually knows what he is talking about. I dont have any part numbers handy right now. The only thing that has me thinking it is possibly an obd1 is that it has yet to throw a check engine light. It now has cam, heads, throttle body, injectors, pretty much the whole top end has been replaced with performance parts. Not to mention all of the smog stuff was also deleted.
Old Apr 8, 2012 | 08:53 PM
bc4850's Avatar
ok I will run out to the garage and look right quick
Old Apr 8, 2012 | 08:56 PM
F0x Slaughter's Avatar
Argh. 95 is OBD1.5 its OBD1 with an OBD2 connector.
Hook up the laptop, plug in the OBD2 connector (which is why I bought the cable with a OBD1 and OBD2 plugs). Start TunerCats, go to ECM, select PCM-EE thats for 94 and 95 LT1s. Turn the car on, wait till like 10 seconds, go to Options and select Com Port Selection and find the port that is open, then hit Tools Read PCM.
Obviously find a new mechanic this guy doesn't know ****.
OBD2 was integrated slowly in 95. Late 95 cars some had it, by 96 it was mandatory that every car had OBD2.
Old Apr 8, 2012 | 08:57 PM
ZFreie's Avatar
Are you sure you were using tuner cats correctly?
Not trying to sound like an *** but I messed it up the first time I used it.
Did you follow his instructions about setting the correct port for tunercats to communicate with?
Also, go find the part # off the pcm, that will instantly tell you what pcm you have.
Was the car bought with the modifications? If so it I'm willing to bet its been tuned before, which would explain why there are no check engine lights. If it wasnt DO NOT DRIVE it with out a tune....
I know nothing about your car so its hard to offer solid advice, you don't have your mods up anywhere either.
Old Apr 8, 2012 | 09:01 PM
bc4850's Avatar
ok well it is an obd1 computer the number you provided for 95 is correct. Yes we did follow the instructions to a t and yes we did find the correct port. I really dont know what we did wrong.
Old Apr 8, 2012 | 09:02 PM
Did you turn the ignition on and wait 10 seconds before trying to read?
If you didn't the PCM is still running checks and it won't let you read it till its idle.
Old Apr 8, 2012 | 09:05 PM
ZFreie's Avatar
Lol, ok guess fox has it covered now!
Old Apr 8, 2012 | 09:08 PM
Thats what I am doing drinking Killians Irish Red haha.
Old Apr 8, 2012 | 09:10 PM
bc4850's Avatar
it is really hard to tell because we tried it so many times.
Old Apr 8, 2012 | 09:14 PM
bc4850's Avatar
its like the program will not recognize the pcm at all.
Old Apr 8, 2012 | 09:15 PM
bc4850's Avatar
No the car was completely stock when I bought it.
The only thing is if you did everything I said correct, if someone programmed the PCM before they could have locked the PCM. Usually this is only done by big name Companies. Not mail order tuners.
EDIT:
Then you guys aren't following what I said then.
Old Apr 8, 2012 | 09:17 PM
ZFreie's Avatar
No idea if your currently driving it but DO NOT DRIVE it till you get it at least mail order tuned, you can cause massive damage to the engine....
Old Apr 8, 2012 | 09:24 PM
bc4850's Avatar
EDIT:
Ok can you walk me through the steps on what to do please? Also what windows software is your computer running?
Old Apr 8, 2012 | 09:26 PM
I am running Windows 7.
You have to install the program a special way under Windows 7 and Vista. If you need me to I can go grab my CD and tell you how to do it.
