Need help on a quick build up.
For 1k what can i do? another friend has a 355 built lt1 short block that just needs one connecting rod he wants 500 for it, if i do this can i use everything of my current motor and leave it?
I want a mid 12 second car thats stilll half way decent on gas so i dont want a huge cam
its a manual 6 speed, not sure the rear end gear but at 80 its right at 2k rpm, im not worried about boltons because i can do all those down the road to get me to where i want to be at, but for the extra 500 dollars what should i do, get the head worked? bore the throttle body?
Ill get the build sheet for the short block just let me know what you guys think
thanks
Chris
"92-97 SS Z28 Trans Am LT1 5.7 350 Engine Block FULLY MACHINED STROKER CLEARANCED AND .030 OVER BORE. EAGLE 383 STROKER CRANK. COMP CAM XR270HR 495-502 LIFT 110 LOBE CENTER. THIS ENGINE WAS ORIGINALLY OUT OF A 93 Z28 CAMARO. THE EAGLE 383 STROKER CRANK CAN BE USED IN ANY 1 PIECE REAR MAIN SEAL BLOCK. BLOCK HAD $ 600 IN MACHINE WORK, CAMS $300 & CRANKS $350. THATS $1200 IN PARTS FOR $500"
What should i look for in the motor wise compression test?
And if you're talking RWHP, you're not even close. To get 450whp look at my signature. That's what it takes.
In a perfect world with high dollar engine management on a dyno with no accessory losses no compromised intake or exhaust for street use the LT4 package makes 425fwhp and more like 330-340 at the wheels in the real world.
You are finding out that"budget" LT1 builds are a bad thing, you had one develop issues on you, then found out the one you were looking at to replace it is no good either.
I would slow down and do a lot of reading before continuing other people's mistakes.
And i was wondering if an aluminum driveshaft is worth it, its off a 2002 ss with 40k miles he wants 80 bucks for it, the cam i found is still in the box from jegs with the recipet and springs he wants 150, my girlfriends dads has lt4 heads which idk if hes gonna charge me for. not even sure if the heads are really worth it, then found an lt4 intake and throttle body both bored to 58mm, wants 300
Stock rebuild lt1 with a hot cam and full bolt ons
or the With the lt4 heads and ported tb/intake hotcam full bolt ons
does it justify the 700 dollar difference cuz he wants 500 for the heads there still in the boxes and wrapped
