Car shakes under light acceleration.
You contradict your self twice in one post lol
Running lean can be from lack of fuel, 12- 14 psi is WAY low, 40+ is what your looking for at the fuel rail. idle and WOT
And if you think the pump failed, why would you say the pressure is not an issue? They go hand in hand, a failed pump WONT push enough gas causing the pressure to be low can cause can a lean situation.
Also not sure why the shop who dynoed your car said it was fine being lean....Do you have any AFRs from the dyno?
(Army)- will check the O2s tomorrow....wouldn't throw a code though???
(Sandman and Z), my bad I meant Air Fuel Ratio from dyno. Pressure was good but still question pump???
I'm fighting a similar issue once my car gets into closed loop. Slight stumble at idle and partial throttle at idle. If you hold the throttle at 1500-2000 rpm at a stop, you can feel it. Funny thing is when I am in 5th, 6th gear..... nothing. It just comes and goes. Going to add cooling paste to the back of my ICM and space it from the head while the weather is bad today so I can test it out tomorrow. New OS's New Delphi Opti, New Wires, New Plugs, New Cat, New Injectors, Cleaned MAF, no leaks I can find. Most of these parts I replaced when I did a refresh of the car, I just noticed the stumble last week when taking off from a light.
