?'s on Drill Mod on PP TB
Difference between you and I is that I learned by doing it, you read about it on internet message boards. How many have you had on a dyno with eight wide bands to actually see the variation in air/fuel? I'm guessing real close to zero.
Many guys I race use Racepack data loggers, and run eight wide bands all the time. We don't have to stagger jet EFI, we correct cylinder-to-cylinder air/fuel variations with the key board. Stock eliminator cars I help use stock throttle bodies and intake manifolds. My Hogan intake has no IAC passeges. Never a problem correcting it.
"if" you have low idle/stalling and have a stock TB on a motor with a aftermarket cam "drilling" out the existing hole 1/64" larger will resolve the idle issue....BUT do not drill blindly as you first need to scan car IAC counts to see if they are maxed out (160 IIRC). The IAC counts want to be 30-35 at idle with engine at operating temp. Once you drill 1/64" larger measure IAC counts again, you may need to drill an additional 1/64" BUT measure IAC first as 1/64" makes quite a diffrence.
Now with aftermarket TB's that have no idle air hole drilled in them like stock and you have a H/C motor with low idle issues you can crack the TB blades open slightly...but you then need to measure your TPS volts because adjusting TB blade position effects the vdc which the PCM reads. You can "slot" the 3 holes in the TPS so you can counter rotate the TPS basically to componsate the same distance you opened the blades up so the TPD vdc reads where it should (.67vdc closed & 4.5 vdc full open BUT there is some variance +/- .67 that is OK at idle)
or drill a hole in the aftermarket TB (start 1/8") and measure IAC and drill in 1/64" incriments until the IAC counts are within spec.
so there are two ways to adjust stock or aftermarket TB's that have low idle issues because IAC counts are maxed. Drill or open blades slightly and also possible slot TPS holes
I mean modifying the existing with a drill bit lol
I usually read your posts as well as Ed's with respect and an open mind, I typically learn something. I don't know why this is such a difficult thing for the two of you to grasp, have you not messed with stock style equipment in a long time?
If you know Mike Acton, ask him about the O2 bungs in the headers be bought from me.
You do know there are individual cylinder fueling tables in the factory PCMs?
Easy fix right there. The factory IAC and cylinder-to-cylinder fueling all goes out the window when heads and intakes are ported. If you ever actually tested and measured things, instead of just typing, you would know this.
How fast is your stuff anyway?
I'm sorry, I don't know the Mike you are referring to with 8 bungs. I'll ask around though.
How would tuning individual cylinders via the fueling tables be a simple, cost effective solution here? Most novices that own these cars don't get into tuning their own car, they either mail order or dyno tune them. So if the factory iac and cyl to cyl tuning all goes out the window when heads and intakes are ported, why did you mention doing it? Do people stick 58mm throttle bodies on stock head/intake cars? Seems kinda dumb to me, must be an internet thing though. Oh you know what is weird? My car has ported factory heads with a ported factory intake AND a corrected 58mm throttle body AND EVERYTHING WORKS FINE! Bank to bank is damn near perfect, just had the injectors cleaned to really balance the banks. I wish I had the money to stick 8 bungs in my primaries and really get things done! For now, I'll stick with the factory bank to bank comparison and let my factory computer do its thing.
How fast is my stuff? Its slow, according to you. Then again, its a car I hop in and drive to the grocery store with. Its a car I let sit for a couple months then drive to a track rental, race, and drive back home. Its a car I built to drive on the street and race a handful of test and tune nights a year, if that. Its a car I drive to work any day I please. I'll tell you what though, it does exactly what I want and when I want! So Ed, how street worthy is you stuff?
Sorry, I assumed when you said 2005 you were referring to electric throttle bodies and the whole lack there of an iac motor/circuit like the 92-97 lt1 motors use, something that Ed brought up. I'm not sure how nearly a decade later's technology applies here? I just try to provide useful, tested, and good information when I can.
Stock: Note hole in IAC circuit
58mm: Note no hole in IAC circuit
Stock: Note hole in IAC circuit and enclosed IAC circuit, open evap circuit
58mm: Note no hole in IAC circuit and open to plenum IAC circuit, open evap circuit
Ported stock intake: Note enclosed IAC circuit and throttle body openings ported to approximately 58mm
Ported stock intake runners: Note IAC circuit feed holes in ported runners, faint dark spots
New 58mm TPiS Throttle Body with corrected IAC circuit
Excellent post, 5 star tech, would read again.
It's not just a bank-to-bank, it's cylinder-to-cylinder.
Nice pics, but I would assume everybody knows what those parts look like.
The factory tuning has most cylinders trimmed differently at closed TPS, different yet at open TPS. The B body cars are different than the F body cars, the LT4 is different yet. Those change with a bigger cam and porting, and more often than not need altered. Less than half don't require tweaked. Each bank's trims are only an average of that bank. Without 8 wide bands all we have are EGTs. If you do enough of this you learn with popular cams & heads how to even them out a bit closer. If, without tweaking cylinder-to-cylinder trims, drilling your TB made your trims even your lucky. I'm happy for you. :-) Doesn't work out that way for many.
Sometime when you have that manifold off, and want to make more power, you need to cut the top off and put a larger radius at the runner entries would pick the flow up a good bit. It is worth some power. Take it off with a band saw, and TIG weld it back on. That is a flow restriction right there.
