?'s on Drill Mod on PP TB
The "drill" mod, start with 1/8" hole, re-scan and if still high drill 1/64" larget. re-scan and if still to high drill another 1/64" larger. often hole is 11-13/64". Take BABY steps as each 1/64" makes a big diffrence
you want IAC counts between 30-35 (32)
Split BLM has more to do with the idle air inlet passage on aftermarket TB vs stock. There are mods to modify that passage.
Car also idles much different cold vs hot. RPMs jump up to 1500 when put in park hot. Will only be at 1000 cold.
New TPS and IAC, professional products 58mm TB. 383 forged stroker by Golen engines, tune by pcm4less.
Running 30 lb injectors w stock fuel regulator, high flow fuel pump. Starting to think I need more fuel pressure.
That is becasue your IAC valve wasn't doing anything with the hole drilled that large. Correct hole size starts at 11/64", with the passage isolated to feed into the individual runners. If its still not idling right go one bit size larger - but that is it.
After that start looking at TPS voltage vs throttle position, stuck IAC, vacuum leaks, clogged IAC holes in the runners, etc.
typically with larger aftermarket TB's, especially on head/cam motors with higher idle RPM set in PCM, you need to do the "drill" mod or the crack open throttle blade/slot TPS holes to rotate it. I don't subscribe to the later.
before you do anything you need to scan the car to see wtf the IAC counts are. often they are pegged at 160 with the IAC maxed out. start by drilling 1/8" hole then measure IAC again. if it didn't drop to 30-35 9often does not) than drill 1/64" larger and measure again. "Generally" with a 383/head/cam motor you wind up with a hole 11/64" BUT again you need to be scaning to read wtf they are each step. 1/64" makes quite a big diffrence.
In the post noting 1/2" hole was drilled....WAAAY to big
The PCM can learn/adjust to a point but ideally you want the IAC counts to be 30-35 at idle with engine at operating temp
Open the throttle blades as far as you can with it still showing zero % throttle angle before doing any drilling. Just having 396" does not mean you have to drill anything. Normally it is only needed with big cams, requiring high idle speeds. Something like a 396" with a cam about the size of the "hot" cam normally can get by without drilling anything. Take a #20 Torqx screw driver to adjust the throttle stop as far as you can, and maintain zero % TPS, and check your warmed up closed loop IAC counts after letting it idle five minutes after start up. If 30 to 35 in P/N with AC off, your good to go.
