Need a stock 94-95 A4 Bin File!
Well im still screwed that file i found did not work. The zipped files i keep trying on brentfranker site are coming up corrupted. Anyone have a 95 Z A4 stock bin file they can send me? My email is vetty_11@hotmail.com.
Thanks Alot!
Matt
Thanks Alot!
Matt
Hey, no problem at all...that is if I still had a 3.5 in floppy drive!
Let me check some of my old stored HDDs. I should have a BDZP.bin file somewhere. Whoops, that is for a 93.
Ok, you will have an email by the time you read this. I have sent a folder with several .bin files for the $EE ecm definition files which I believe are the 94-95 pcms. My current cars are the DA2 and DA3 files and although I am pretty sure I have the $EE def file wherever my licensed RT tuner is located I certainly haven't seen it on a PC I can get to easily in years.
The one you should check out first are the files with Matt in the name. His car was a stock 94 M6 car so it may not control that years 4L60E.
Good luck.
Perry
Good luck.
Perry
