battery randomly dies....need help
[Edit] Kinda already been mentioned, but definitely check the electrical connector on the back of the alternator. That's the exciter wire which basically tells the alternator when to charge. The female pin in my connector broke and caused a lot of voltage fluctuations due to poor contact -- until I found the problem.
Try getting a new alternator they're not crazy expensive, or see if you can swap with a buddy that has an LT1 real quick.
