DTC 16 - Tested... Opti?
Got a dtc 16 low res failure on a 1994 A4 Z im working on. Did the voltage readings and all came close to spec on the opti harness so i guess its safe to say were in for a new distributer from what i read.
Opti Harness
A - Should be 5vdc - Was 4.99dvc
B - Should be 5vdc - Was 4.99vdc
C - Should be 12vdc - Was 11.03vdc
D - Should be 0-0.3vdc - Was 0.03vdc
Opti Harness
