lt1 won't start
The car had been sitting a bit so I drained the gas and changed the filter. Went to crank it and it turned over but it just sputtered. I checked for fuel pressure (had about 40lbs just primed and sat there for 2 hours while I was gone ) I then tried to start just for the hell of it and noticed one of the almost 20 year old wires was cracked so I had a set of plugs and wires from my other ta that I never used so I threw those on. I then just gave it another try for the hell of it and after a bit it fired and ran bad then it shut off and wouldn't restart. No it just stutters and backfires threw the intake it seems. Any ideas would be great thanks
So far I've :
Drained the tank and blew the lines out ( added 6 gallons of fresh stuff )
changed the fuel filter
changed plugs and wires
tested for spark and fuel
pulled fuses all were good
looked for any messed up wiring or something unpluged saw nothing
Worst comes to worst I have a pretty new opti in the garage but damnit I'm lazy and don't want to change it heh
