new gear install question!!
Old May 6, 2012 | 09:21 PM
ramair 1's Avatar
Default new gear install question!!
Hey guys im putting in some 373's this week .Do i need to do anything with the ecm ? Its got the 323 stock set in it now with the A4 tranny.
Old May 6, 2012 | 09:22 PM
F0x Slaughter's Avatar
Your speedo will be off.
Old May 6, 2012 | 09:28 PM
ramair 1's Avatar
If thats it no big deal ,i was worried about the shift points being all outa wack.
Old May 6, 2012 | 09:30 PM
TravisMcGill2000's Avatar
The shift points will b messed up. U will probly hit limiter at wot shifts
WS Sick's Avatar
If it has a 4L60 E the shift points will be WAAAAY off.
Old May 6, 2012 | 09:36 PM
ramair 1's Avatar
I dont think anyone around me tunes lt1,s that could be a problem!
Old May 6, 2012 | 09:40 PM
WS Sick's Avatar
If you don't get it tuned it will eat the tranny in a short time.
Old May 6, 2012 | 09:42 PM
ramair 1's Avatar
Who does good mail order tunes?
Old May 6, 2012 | 09:44 PM
WS Sick's Avatar
Bryan Herter at PCM for less and ther are a few others here as well, their names escape me. If you have a laptop and are willing to learn to do it the software and cable will be right around 100 $.
Old May 6, 2012 | 09:48 PM
ramair 1's Avatar
Yeah i am on one now, where can i get this stuff? Its for a 97 ws6 .obd2
Old May 6, 2012 | 09:52 PM
WS Sick's Avatar
Aww OBD 2, I converted mine to OBD1 for just the reason of the price of the software and the availability...lol. I'm not the one to ask about OBD 2. Maybe someone else here can point you to a good tuner software or a handheld that can do what you want.
Old May 6, 2012 | 09:56 PM
ramair 1's Avatar
I got excited there for a second i thought you new about something ive overlooked.Thanks anyway WS SICK!!
Old May 6, 2012 | 09:58 PM
Convert to OBD1 all you need to do is swap the PCM.
Old May 6, 2012 | 10:02 PM
ramair 1's Avatar
Thats lookin like the most logical answer at this point.Whats the goin rate on obd1 ecm?
Old May 6, 2012 | 10:07 PM
Depends I got one off a guy for 50 plus shipping. A lot of people charge like 100.
Old May 7, 2012 | 09:32 AM
SS RRR's Avatar
Village Troll
IIRC, knock sensor too.
Old May 7, 2012 | 11:17 AM
I thought it was just the knock module which is in the PCM?
I know the knock sensor is a different ohm range though on the OBD2.
Would have to look into it.
Old May 7, 2012 | 11:39 AM
SS RRR's Avatar
Village Troll
Knock module is the same (other than the LT4 KM). Knock sensors are different. Either the sensor can be changed or the correct resistor can be soldered into the PCM.
Old May 7, 2012 | 11:41 AM
I would do it the correct way and just change out the sensor IMO.
Old May 7, 2012 | 12:09 PM
quik95lt1's Avatar
there is no reason to spend the $$ and time going to an OBDI all he did was put gears in the car lol.......just find a tuner to do the OBDII.......OP where are you located?
