new gear install question!!
#42
in reality 96caprice is correct........if you DO NOT change anyting in the computer including NOT correcting the speedo the car will still shift exactly the same......if you correct the speedo and DO NOT correct the shift points.....then it will be off........
look at it this way (i know these numbers areent accurate but lets use them for demo purposes)
lets say our test parameters are.....
7000rpm shift point
6' run out on our tire
3.06 1st gear raio
3.73 gear which we will swap out to a 4.56 in the second part of this....
TsRPM=Tailshaft RPM
TrRPM=TireRPM
Erpm = Engine RPM
Scalar= Speedo Scalar that ECM uses to calculate mph from VSS (my mehtod is for demo purposes actual calcculation is far more complex)
so....7000 Erpm /3.06 (1st gear ratio) = 2287 TsRPM
2287/3.73 (rear gear ratio) = 614.3TrRPM
614.3 * 6 = 3685.8ft/min = 41.88mph
so for a speedo scalar we have
2287TsRPM/41.88mph = 54.60 Scalar
so the pcm is programmed with a 54.6 scalar the speedo is correct and it shifts at 2287TsRPM which is 41.88 mph and 7000rpm.....
now your buddy came out and kicked your teeth in with his LS1 and you swap in 4.56's to catch him...........but you DO NOT change your tune AT ALL......
so....7000 Erpm /3.06 (1st gear ratio) = 2287 TsRPM (NOTICE THIS PARAMTER HASNT CHANGED)
2287/4.56 (rear gear ratio) =501.53TrRPM
501.53 * 6 = 3685.8ft/min = 34.19mph
2287TsRPM/34.19mph = 66.9 Scalar
but you never changed the speedo scalar in your desperate attempt to beat your buddy.......the computer still calculates thinking its got 3.73's.....is your speedo off your "actual" speed........hell yes.......but does the PCM have any idea......nope........the pcm says your doing 41.88mph still at 7000rpm regardless of you actually doing 34mph according to your fancy gps on your dashboard.......the pcm sees that 41.8 and bam it shifts........
now lets say you change the pcm scalar but never change the shift points....well now ya got a problem......
lets say you change that scalar so now at 7000rpm the pcm tells your speedo its doing the correct 34 mph........your shift tables are still at 41mph......unless you got a really good valve train or a rev limiter your going to be picking up pieces............
that should clear all this mumbo jumbo up........plain and simple.....if you leave it alone and deal with the incorrect speedo its all good.......but if you do decide to correct your speedo by changing the gear ratio in the tune.......change ur shift points also.....simple math will show you how much
3.73/4.56=.817 so you need to decrease your shift points and tcc lockups by (1-.817= .183*100= 18.3%) 18.3%.......41.88*.817= supprise supprise 34.21.....so you just scale it by -18.3% and you are good to go........
however due to the added accleration rate of the gears now in 1st gear I add 2% to the first gear calculation and 1% to the second gear to allow the ECM, solenoids and trans extra time to shift because its time is greatly reduced now because of the acceleration rate of the rpm of the engine due to the lower gear......just a little tuning tip
hope this helps
7000rpm shift point
3.06 1st gear raio
TsRPM=Tailshaft RPM
TrRPM=TireRPM
Erpm = Engine RPM
hope this helps
#44
Yep if its not corrected the shift will happen at the same mph, the mph just will be off.
Thats what I said.
Forgot to add, RPM when in D has no bearing on the shift. Manually shifting, yes RPM has a say.
Sorry , at work my edit button does not exist..lol (firewall) anyway In Tunercat, when you change the scaler to compensate for your new gear ratio, it atumatically changes the MPH in your shft tables to reflect your new gears.
Edit again, yes if you change nothing and your WOT shift is at 7000 it will still be there. Part throttle and tooliong around will be annoying as crap (think waiting for shifts or being in OD in less than 100 feet from a start) but if you just don't look at the speedo on WOT your shift will happen at 7000 RPM.
Thats what I said.
#45
Thanks quick95 and everyone else for the input on this .I will be finding someone or some way to set the correct ecm tune before i start driving it. The car is only driven about 500 miles a summer so i dont care to wait till its set up right.
#47
correct the pcm does a calculation off of the pulses it recieves from the vss to determine the mph........yes the vss will turn the same speed however the final number that the computer uses for calculation will be off because of the gear multiplier its using......the speedo will read lower than it actually is going
It doesnt it is dumb as far as that is concerned and only has the VSS signal to tell it whats going on out back. It plugs the number of pulses from the VSS into an equation (the other part is th gear ratio and tire size) and then determines what speed the car is going, if the math equation is off the speed is off that it beleives the car is going, when in reality it is going a different speed.
No it won't! Believe me .... we took and A4 car with original 2.73 rear gears in it, and swapped them up to 4.56's. to make a bracket race car and without re-programing the PCM .......... the trans would upshift to third gear by 23 mph during light throttle/cruising.
#49
What do you mean 6,000 rpm is 41 mph to the PCM regardless of gears???
#50
I was throwing out a number.
245/50/16 tires on a4 with 3.23 is 44mph at 5700rpm in 1st gear.
3.73 is 38mph.
VSS uses tail shaft rotations and a scalar formula in the PCM to tell the speedo what the mph is. If you change the gears in the axle it doesnt affect the VSS. So if you do not correct the speedo, when you hit 5700rpm the PCM thinks the car is going 44mph and will shift, in reality the car is going 38mph. But as discussed the PCM will have no idea the car is doing 38mph because the scalar in the PCM tells it that you're doing 44mph.
Since shifts are dictated by mph it doesnt matter what gear or tire size you have as long as you don't correct the speedo.
If you correct the speedo and don't change the shift point you will need to spin 6600rpm if your shift point was 44mph, with 3.73s.
Also a stock m6 with 3.42 and 245/50/16 tires at 6000rpm is doing 50mph. In 4th is doing 134mph. Remember the tach on the dash is about 200-300 rpms high.
Also a4 with 245/50/16 and 2.73 is doing 55mph at 6000 in 1st. With 4.56 is doing 33mph. The speedo still thinks its doing 55mph though.
3.73 is 38mph.
#51
3.73 is 38mph.
Since shifts are dictated by mph {yep, you got this part right!} it doesnt matter what gear or tire size you have as long as you don't correct the speedo. {but, no, unfortunately, you got this part wrong! (see below)}.
3.73 is 38mph.
The fallacy of your logic however, lies in thinking that the trans will shift based on engine RPM. What WS Sick and I are saying is that the PCM commands transmission shift points based on MPH.
Let's use this VERY simple example:
An A4 car is properly programed to make a 1-2 transmission shift at 25 mph which occurs at exactly 1,000 driveshaft RPM, with it's 2.0 to 1 rear gear ratio. So in this first case 25 mph happens at 1,000 driveshaft rpm with those 2.0:1 rear gears, and the TRUE vehicle speed is 25 mph. (Because, again, everything is properly programmed in the PCM for those 2.0:1 rear gears, and a VSS input to the PCM of 1,000 driveshaft RPM).
Now we JUST change to a 4.0 to 1 rear gear and do NO re-programing whatsoever to the PCM. Now again at 1,000 driveshaft RPM, the VSS, once again, "tells" the PCM we're at 25 mph, and the PCM, (based on NO change in either it's programming or any different input signal from the VSS), commands the transmission to ..... do the 1-2 upshift!!!! Which it does do at a TRUE vehicle speed of only 12.5 mph. See, the trans upshifts TOO early because it's programed to shift at 25 mph ....... which it "thinks" it is at, but ....... it isn't. After this upshift we are now in 2nd gear at a TRUE vehicle speed of only 13 mph!!!
#52
Yes it does! And so does the PCM, which now was originally programed to be waaaaay into 2nd gear at 55 mph, but ....... the car is ONLY truly going 33mph ....... right?
#53
Also remember though the shifts are dictated by TPS% also.
Here are the stock tables.
1>2 2>3 3>4 2<1 3<2 4<3
0.0 11 20 30 9 18 27
6.3 12 22 34 9 18 27
12.5 15 28 44 9 19 27
18.8 20 36 54 9 19 27
25.0 25 46 64 12 19 27
31.3 29 54 74 12 20 30
37.5 34 64 84 12 22 35
43.8 38 72 94 12 27 43
50.0 40 76 104 12 31 49
56.3 42 80 114 12 36 56
62.5 44 84 124 12 42 65
68.8 46 88 160 12 51 72
75.0 48 92 160 12 57 78
81.3 49 94 160 12 68 152
87.5 50 96 160 12 68 152
93.8 52 98 160 40 90 152
100.0 52 98 160 40 90 152
2000rpm is 15mph so you would have to have the TPS as 12.5% for it to shift at 2000rpm with 3.23 gears. Now if you switch to 3.73 gears, 15mph would be 2200rpm. 2000rpm with 3.73 is 13mph. So it would shift 3mph lower with a 3.73 gear as opposed to 3.23 gears.
55mph is 2nd gear at 3800rpm.
So yes I see where you are coming from. A huge gear change from 2.73 to 4.56 is a huge difference and would require a PCM before drivable.
A 3.23 to a 3.73 wouldn't its only a 3mph difference.
Should you get a tune yes, but it wouldn't be necessary.
#54
