Heads/Cam advice
going to be ordering my heads and cam here in a couple of weeks, any reviews on these?? or are they a good choice for my street driven weekend warrior?
Goal is to get into the low 12's
http://www.summitracing.com/parts/TFS-30400008-M54/
http://www.summitracing.com/parts/TFS-31402081/
any advice would be appreciated
Do a search in this particular forum on the subject, most lean towards the AI 200 or the LE2 or 3 (AI= Advanced inductions, LE = Lloyd Elliot Portworks)
Honestly, I would send in your stock heads and have them ported by LE or AI as mentioned above. And then get a custom grind cam from them or have them reccoment you a cam for your goals for your car. I personally went AI and couldnt be happier but i'm sure you wont be disapointed with either choise as they are both proven to be pretty good.
I'd go ported stocker too. I love mine. If you don't want to be without a car while youre waiting on your heads I've got a set of stockers sitting in my garage waiting for someone to buy. X2 on the custom grind. Wether you go with Lloyd or AI if you call them and give em you're info they'll custom spec you one right there. They are both great to work with.
