Is this my fuel gauge broken? New cluster time?
Ok last thread on this issue I promise.
I thought my problem was my dual walboro install but now I think it isn't... I now get 26 ohms at the connector from the sending unit (which is about accurate, tank was near empty and I put like 4 gallons in it). I chased the wires inside the car and all the way up to the dashboard and ground under the driver's seat I get ~26 ohms still. But my gauge reads empty (pumps work though). If I unplug the connector the gauge reads full.
Did you install a new sender??? Those lil deals where the float arm slide up & down get Wore out My S10 Blazer drove me nuts till I got an A/C Delco pump & sending unit After that things were fine A mid 90s LT1 ***** wore out replace it Install a hotwire kit PER PUMP & your done UNLESS you pinched a wire somewhere like the bellhousing/motor Did that once on an S10 LoL Erratic ohmmeasurements would tell me the things WORE OUT
I agree with cluster if everything ohms out. If not correct i have seen many more times the purple wire going into the sending unit be burnt up and cause bad reading sometimes and good reading other times. Very common on all gm sending units. Your case sounds like the cluster is starting to go out.
