Cam info?
Stock crank is far superior to an aftermarket cast crank.
Did he have a turbo or supercharger on the car?
What RPM does the car pull hard? Tight LSA creates a narrow power band, increases torque, and moves the peak torque to a lower RPM.
I bet that cam has a pretty good lope.
6300rpm is really the safe range of a stock bottom end.
That cam though obviously would probably max out right around that 6500 mark. But until you find out what has been done to the bottom I wouldn't push it past 6300 a lot.
If you can feel it fall off at 6500 then it is likely the springs are worn out.
That much duration with a "bigger is better" kind of head it would likely be near/past peak at 6500 but should be slowly losing power not a sharp enough drop to feel SOTP.
