lt1 fuel pressure bleeding down
Old May 15, 2012 | 04:52 PM
F0x Slaughter's Avatar
I know you said the setup ran before but did you keep the same sized injectors that are in the tune?
Also do you have constant spark?
Old Jun 12, 2012 | 10:47 AM
jrod_z28's Avatar
Did you ever figure out the problem?. I'm having the same issue with my 97 Z28
Old Jul 11, 2012 | 10:13 PM
95sscamaro's Avatar
Yes, the fuel pressure regulator would stick closed causing the fuel pressure to build to 85+ psi and it was blowing past the injectors. New FPR and plugs fixed it.
