Lt1 th350 and vss
Old May 20, 2012 | 03:09 PM
AChotrod's Avatar
Originally Posted by starbucks
@jpack my tails haft is the 9" version I'm just not looking to spend alot money. @ Ac does your car set a code when you do a burn out at the track?
Never had any issue at all before the tune was changed. Very easy to do if you delete the ABS.
Originally Posted by 94Z28rag
AC - Can I just plug in the VSS into that plug on one of the front wheel hubs?
I spliced mine together not sure if it would plug in.
Old May 21, 2012 | 07:08 PM
the_merv's Avatar
Veteran: Air Force
I just converted my TH350 into electronic VSS using the Fitzall Spacer and some parts I scrounged up. I'll post pics tomorrow when the Spacer comes in and I bolt it all up..
Old May 21, 2012 | 09:32 PM
merim123's Avatar
curious, why did you give up on the abs for this?
Old May 21, 2012 | 09:45 PM
the_merv's Avatar
Veteran: Air Force
The ABS one I had setup went **** up, and I want the TH350 I have to be more versatile..
That and Trans mounted VSS is pretty dependable.. I think the sensor went bad in the ABS Hub which caused the failure..that is the only thing that doesn't check out, the wiring is good.
Old May 21, 2012 | 10:29 PM
merim123's Avatar
cool. why not the stock gm parts to do this? I believe you have to get the reluctor from the 1990 454ss trucks as they had th400 in them. shouldn't that be a stock solution? or will not fit the th350?
Old May 21, 2012 | 10:46 PM
the_merv's Avatar
Veteran: Air Force
The output shaft has to be modified..there is a kit out there, you have to tear down the Trans to install it.
I kinda did something simple and effective..
I'll link the thread in here tomorrow.. It'll prob end up being a sticky in the auto section, I haven seen anyone else do what I did.
Old May 22, 2012 | 05:56 AM
joelster's Avatar
Here's my spare th350 with the reluctor ring in the correct spot and the spacer installed.
I looked around the reluctor on both sides and it doesn't appear to be welded or anything. Just looks like a snug press type fit. I had to use the 4L60E tail cone on my new th350. My local shop has done a ton of these conversions.
Old May 22, 2012 | 08:46 AM
the_merv's Avatar
Veteran: Air Force
Did they use a bushing or is that the Output Shaft that has been welded up and machined down?
Old May 22, 2012 | 10:43 AM
starbucks's Avatar
So quick question with the fitzall part and a 9 inch tail shaft do you still have to change out the tail shaft with the one in the fitzall kit? Or can you just press on the Reluctor wheel?
Old May 22, 2012 | 12:09 PM
the_merv's Avatar
Veteran: Air Force
Reluctor won't press on a stock one..they take a stock shaft, weld it up and lathe it back down to have metal in that spot where the Reluctor is on.
I used a T56 Reluctor..about to get the Spacer and put it together.
Old May 22, 2012 | 12:14 PM
AChotrod's Avatar
Guys you sure make this complicated. Took me like 10 minutes to make mine work. lol
Old May 22, 2012 | 01:51 PM
  #32
starbucks's Avatar
@Ac your right about making it more difficult that I really needs to be my only worry when I need to get the car dyno tuned how is the PCM going to know the car is moving on a dyno.
Old May 22, 2012 | 02:01 PM
  #33
merim123's Avatar
so share the 10 minute solution for everyone to learn
Old May 22, 2012 | 02:07 PM
  #34
AChotrod's Avatar
Take the VSS wires from your old trans and splice them into your abs speed sensor. No problems with the car running what so ever.
This is a vid B4 I even tuned the speedo to work right.
http://www.youtube.com/watch?v=G9Ti5YqcFTk
Old May 22, 2012 | 03:12 PM
  #35
starbucks's Avatar
^ my car did not act like that infact mine would not idle at all with out giving it gas. And would have died after the burn out.
Old May 22, 2012 | 03:31 PM
  #36
AChotrod's Avatar
Then its something else with your car or you have the wrong wires hooked up. Ill see If I can get you some pics of the wires I hooked up. You sure the NSS is working?????
Old May 22, 2012 | 03:34 PM
  #37
starbucks's Avatar
Yes because it only start in park and nutral. That vss wires where not hooked up at this time. Is there a certain cooler pattern I need to go by, I wouldn't think because it is just a magnet.
Old May 22, 2012 | 04:31 PM
  #38
AChotrod's Avatar
It didnt matter what color went to what color if I remember right. But when I get a chance Ill take pics of exactly what I did. Maybe tonight but I wont be home till 8:30-9
Old May 22, 2012 | 07:07 PM
  #39
joelster's Avatar
My setup isn't just about keeping the speedometer. It's more about keeping the tail of the 4L60 so that it bolts up perfectly to my crossmember so I don't have to buy a new one. The shop that built my transmission was well versed in building these conversions. I don't need the feed for my pcm or anything.
Old May 22, 2012 | 09:08 PM
  #40
AChotrod's Avatar
Oh gotcha thats a good reason then. I just got a UMI conversion cross member
