Lt1 th350 and vss
Old May 15, 2012 | 02:02 PM
starbucks's Avatar
Default Lt1 th350 and vss
Does anyone know if I can do the vss (vehicle speed sensor) to Wss (wheel speed sensor) to get the speedo to work with out programming? I do not care if the speedo is correct I just need the vss code to go away do the car will idle.
Old May 15, 2012 | 02:55 PM
merim123's Avatar
with ls1 computer you can do that mapping, not sure if you can with the lt1 pcm.
Old May 15, 2012 | 03:32 PM
starbucks's Avatar
Mapping for what, I just need to know if pluging my vss into a Wss will tell the computer that the car is moving.
Old May 15, 2012 | 03:40 PM
WS Sick's Avatar
I know if its like the 700R4s WSS it will go away. But I'm unfamiliar with what came on TH350s.
Old May 15, 2012 | 06:14 PM
starbucks's Avatar
To the top
Old May 15, 2012 | 08:34 PM
gregrob's Avatar
No it will not work without programming...
Old May 15, 2012 | 08:44 PM
joelster's Avatar
What I did for my th350 swap to get the speedo to work is listed below.
th350 with a 9" tail
Fitz-all adapter kit ( a big spacer )
install the 4L60 reluctor wheel onto the th350 output shaft
remove the tail cone off of the th350, then put the Fitz-all spacer and the tail from a 4L60 in its place. That way the sensor plugs right into the tail and it still gets the proper signal to operate the speedo.
Old May 15, 2012 | 11:58 PM
the_merv's Avatar
Veteran: Air Force
^^^ That.. You happen to have a link for that Spacer? I have the other parts..
Old May 16, 2012 | 06:15 AM
joelster's Avatar
http://www.teckpak-fitzall.com/lpgm.cfm?id=7-35C&type=I
Old May 16, 2012 | 11:17 AM
starbucks's Avatar
Thanks guys for the help, any idea on how much this costs? And if I can t56 Reluctor wheel?
Old May 16, 2012 | 11:38 AM
Jpack's Avatar
How long is your tailshaft housing? There are places to get a set up the same size with the vss sensor set up. My Rossler trans came with a 9" tailshaft with a ls1 type sensor in it. You will have to weigh your options on what you want to do. Cheap way of using wheel sensor and reprogram, an adapter and shorten the driveshaft, or new tail shaft housing and sensor. Even the last will require a flash of the pcm. You can also disable the vss code in the pcm to diagnose. If you have a cable and laptop I'm sure asking someone here to look at your current tune and switching it off or program the wheel sensor would make a lot of sense.
Old May 16, 2012 | 11:44 AM
AChotrod's Avatar
I wired my VSS to my abs wheel speed sensor and it worked just fine with no issues except the speedo was off. My tuner corrected it and its almost dead on now.
Old May 16, 2012 | 02:03 PM
starbucks's Avatar
^^^^ thank you AC that is the information I was looking for. I don't care if the speedo is right I just don't war to vss code to come on.
Old May 16, 2012 | 02:06 PM
starbucks's Avatar
@jpack my tails haft is the 9" version I'm just not looking to spend alot money. @ Ac does your car set a code when you do a burn out at the track?
Old May 16, 2012 | 02:24 PM
Jpack's Avatar
You are still gonna throw codes...has to be reflashed as a 6 speed car....
Old May 16, 2012 | 02:28 PM
94Z28rag's Avatar
AC - Can I just plug in the VSS into that plug on one of the front wheel hubs?
Old May 16, 2012 | 03:01 PM
starbucks's Avatar
@ jpack the car was 6 speed car to begin with.
Old May 16, 2012 | 03:39 PM
the_merv's Avatar
Veteran: Air Force
I run the TH350 currently off the Wheel Hub (2000 Blazer front Spindles, ABS Reluctor), but I want to put it on the Trans for my S10 since it doesnt have the Reluctor.
That's the instructions..I take it you got it from a dealer?
Old May 16, 2012 | 05:40 PM
joelster's Avatar
I used that link so you guys could get an idea of what the kit does. I had my local shop order the part.
Old May 17, 2012 | 08:55 PM
the_merv's Avatar
Veteran: Air Force
That Spacer is exactly what you got?
From my understanding that instruction link takes a 700R4 to a 3 speed?
But that spacer and 700R4/early 4L60E Tail Housing with a non-lockup TH350 make a readable VSS?
