Lt1 th350 and vss
Old May 22, 2012 | 09:18 PM
  #41
starbucks's Avatar
^ I just happen to make my own with some metal, a welder, and some time. Turned out really good just needs to be powder coated.
Old May 22, 2012 | 11:47 PM
  #42
the_merv's Avatar
Veteran: Air Force
I had mine on the Wheel Sensor and I lost speedo while driving, so I put it in the TH350. Good VSS, good wiring to PCM and still no speedo. Something went to ****.
Old May 23, 2012 | 10:45 AM
  #43
the_merv's Avatar
Veteran: Air Force
I think my problem is a ground in my Harness went bad..found a spot where it was rubbing sheet metal on the car. Goin to check that later..
However....
https://ls1tech.com/forums/automatic...th350-vss.html
