Dead cylinder
Old May 16, 2012 | 11:40 PM
icedragon642's Avatar
Angry Dead cylinder
Ok guys, I got a dead miss can't figure out whats causin it. My check engine light is not coming on and I know for sure it works. It's driving me nuts trying to figure it out. Any ideas would be appriciated!!!
Thanks
Ron
93 Pontiac Trans Am T-Topped and a 6-speed LT1
Old May 17, 2012 | 06:15 AM
RamAir95TA's Avatar
Specify the problem. Is it at idle, load, part throttle, wide open, etc.? Fuel pressure okay? Wires arcing, plugs okay?
Old May 20, 2012 | 03:39 PM
It misses at normal load, if I run wide open it doesn't miss. Fuel pressure is ok plugs are new ( I tried changing plugs first thing same with wires ). I'm stumped, so any ideas are truely appriciated!!!
Old May 22, 2012 | 06:45 PM
DisasterFormula's Avatar
Try running some Seafoam. Maybe a clogged injector?
Old May 22, 2012 | 07:04 PM
joelster's Avatar
If it misses at idle and it is ignition related, try hooking up an old school timing light. Simply start the car and depress the timing trigger and go from wire to wire. It should strobe on every wire. If it doesn't on 1 particular cylinder try replacing that wire. Some guys use one of those infrared temperature guns too and shoot each header tube. If you find one significantly colder then it isn't firing properly.
Old May 27, 2012 | 12:12 AM
Thanks guys!! I'll give your ideas a try.
Old May 27, 2012 | 07:15 AM
SS RRR's Avatar
Village Troll
Or you can just simply disconnect each fuel injector clip, see if idle changes, if not then plug it back in and move on to the next one. Repeat until you pull one of the clips and the idle does not change. That will be your dead cylinder.
Old May 27, 2012 | 09:09 AM
Jason94z's Avatar
i suspect bad plug or wire if you are getting no SES codes
Pull plugs to see which one is weird/fouled
or idle from cold and sprinkle each header tube with water - the one that does'nt sizzle is your problem and take it from there pulling that plug
Good luck!
