ICM, opti or coil problems
Go to www.shbox.com for the voltage readings you do on the coil, icm, and opti harness to see where you stand and where the problem resides. Do no just throw parts at it hoping to fix it.
I have a new ICM I am putting on so I hope this is going to fix this.
I have a feeling not. I do throw the random misfire code once in a while when it is running rough.
Thanks for all your help!
Honestly, having a laptop and buying the aldl cable is the way to go. Scanning the car takes 3 seconds and no more guessing at what COULD be wrong, its usually very obvious.
.02
Sounds closed loop related based off that.
.02
