le2 or le1
So I was thinking on getting some heads and cam since I'm gonna have to pull out my motor I've heard a lot of great thinks of the Lloyd Elliot setups..I would love to get one of them but really don't know which one to go with..I want to keep the bottom end stock..would the le1 be good or the le2 I'll new glad with like 360Rwhp at least..around how much would everything run..also would a pcm for less be a good tune?
Any help would be appreciated
You should look into A.I., I wanted LE, then was enlightened into the A.I head and cam setup. You can get prices on their websites. If you go with LE, your going to want that little more, so just go with le2. it is only 400 more, or so beats having to pull it off again later on, if your not happy. LE is done by hand if I am not mistaken and AI is dont by computers and machining
When it comes to stock castings, AI uses CNC machining, LE is old school hand-porting.
LE is great if you're on a budget, but go with AI if you want every last drop of potential out of the stock castings. Keep in mind you'll probably only want to do the heads once.
In my personal opinion I would go with LE every day of the week and twice on Sunday. I bought some LE2 heads and a LE1 cam and made 422 Rwhp and 412 Rwtq you can't do that with AI for the same price. Oh and that was through a 9 inch rear end
@96capricemgr best to date on motor is 11.48 @ 118 and on spray 10.23 @ 128. That part that I was impressed with the most was the horsepower under the curve compared to other people dyno sheets and the toque is flat all the way across.
IMO mid 11s at 118 does not support that dyno chart.
I would not claim my car would dyno that high and it runs within .1 and 2mph and is certainly heavier.
Hell you dyno HP is close and tq much higher than the fastest NA stock shortblock Impala that is heavier and half a second 4mph faster than you.
Dyno like the flow bench doesn't tell the whole story.
I would definitely give him a call though and talk to him and tell him your plans for the car.
Village Troll ![](http://jameskellock.tripod.com/sitebuildercontent/sitebuilderpictures/rsman.jpg)
Which voids what you stated earlier in your post. You can't doubt dyno numbers and compare them when we have no idea of track conditions/elevation and transmission used. If it's a manual car those numbers aren't far off 118mph through the traps.
