Code 63
Old May 28, 2012 | 02:29 PM
1Bad93Z's Avatar
Default Code 63
I've noticed over the past few days my air/fuel gauge has been showing and extreme rich condition. No codes were present...however today my light came on with a code 63 present..."bank 2 right heated oxygen sensor, open circuit" 2 questions...would this cause my a/f ratio to go retarded, and is this a failed sensor or wire? Thanks
Old May 29, 2012 | 08:11 AM
DisasterFormula's Avatar
Check the connections on the wires. If there's some corrosion in there, clean it up and see if it checks out. But in all probability, it's a bum sensor. Bad O2 Sensor or connections to the sensor means the computer isn't getting correct feedback so it starts running rich to avoid going too lean and detonating the engine.
Old May 29, 2012 | 08:47 AM
1Bad93Z's Avatar
Thanks a ton for the answer. My A/F gauge is full rich until I let off, then it goes to mid 13s. Now, bank 2 right is the one on the passenger side coming off the header?
Old May 29, 2012 | 09:24 AM
Yes, Bank 2 is the passenger side. Lucky us on OBD1, we only have the pre-cat sensors. If your A/F is at 13, that sounds about right for the stock tune. I dunno how rich it gets at WOT. Is the gauge for both sides or after the merge or do you have separate gauges for the sensors?
Old May 29, 2012 | 09:37 AM
1Bad93Z's Avatar
Its not a stock tune, before last week everything was as it should be as far as what the gauge was reading. My wideband is right after the Y pipe. I am however going to be making an appointment for dynotune in the next couple weeks.
Old May 29, 2012 | 02:03 PM
If everything was running good before you started throwing the code, check the connections then the sensor. Those should put you back to being right as rain on your a/f mix.
Old May 29, 2012 | 02:17 PM
1Bad93Z's Avatar
Thanks bud, appreciate it.
Old May 29, 2012 | 02:28 PM
You got it, man. We're all here to help each other. Except for the trolls and scammers. Fcking troglodytes.
