Help!! Oil Cooler
Old Jun 8, 2012 | 05:21 PM
ManMuchwano93z28's Avatar
Default Help!! Oil Cooler
I blew out the oil pump in my car and I took off the oil cooler and it was all filled with shavings I been looking for a new one but I can't find it anyone know where I can get one. The gm part number 10168415
Old Jun 8, 2012 | 05:49 PM
Ocala93TA's Avatar
probably used is the only place to buy it , i would remove it completely my 2 cents
Old Jun 8, 2012 | 05:57 PM
You think it will be ok to fun like that... It's my daily driver
Old Jun 8, 2012 | 06:20 PM
Ocala93TA's Avatar
Yes most guys pull them off anyway when they go with headers to gain room. i have a 503 cam DD and no issues at all
Old Jun 8, 2012 | 06:36 PM
defaultexistence's Avatar
Very common to delete the oil cooler it's a piece of ****... U Wana cool something ?Add a trans cooler.. Now that is worth it's weight and price for it's help making the trans last a little longer Especially on a auto DD. IMo
Old Jun 8, 2012 | 10:03 PM
Ok I thought I had to have it cause it's my daily driver and I take long trips all the time with it I guess I'll delete it for now and keep and eye out for one at swamp meets and stuff.. Thanks for the info guys
Old Jun 8, 2012 | 11:38 PM
tricked94camaro's Avatar
if u need a oil cooler i have one. what year tho? not sure which years are interchangable.......
Old Jun 9, 2012 | 03:12 AM
It's a 93 how much u want for it..??
Old Jun 9, 2012 | 10:56 AM
Badazz 97 TA's Avatar
i would leave it off. its useless
Old Jun 9, 2012 | 11:10 AM
check to make sure a 94 would fit. as much as id like to make a few bucks off it, i would do what the others are saying and delete the thing. its really easy. i just did it last week.
Old Jun 9, 2012 | 12:35 PM
What's the part number in the oil cooler is it 10168415
Old Jun 9, 2012 | 03:55 PM
I checked up on it everything seems to be compatiable so I'll take it I pm u my number so call me when u can the sooner the better
Old Jun 11, 2012 | 12:38 AM
call u in the am dude its a bit late lol sorry im just getting back now!
Old Jun 11, 2012 | 01:00 AM
FAD2BLK93's Avatar
I just did the 503 and headers myself...i have clearance with mac headers. But i had the choice to take mine off or leave it on, i left it on the car. I have a meziere electric water pump on it and my water temps are very very low, so i would also think that my oil temps are low as well. Would someone please tell me why my cooler would be considered a POS. I would think the GM engineers would know something good right? Capricemngr what do u know on this subject? Thanks
Old Jun 11, 2012 | 08:43 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
I'm pretty sure they did not use these coolers on the LT1 Corvettes, and I believe it may have been due, or partially due, to Mobil 1 being the factory fill. Supposedly, the coolers are prone to clogging. I know when I removed mine, my oil pressure improved dramatically, but I also changed filters at the same time, so there was more than one variable involved. On the bright side, the coolers used on the earlier model Z28s were supposedly superior in design to those used on the later models. At some point, I think GM quit using them altogether on these cars. Personally, I would remove it and not worry about it. If you ever run a long tube header in the design of Kooks LT1 headers, the cooler will have to be removed.
